Clutch Install Question
Old May 17, 2005 | 08:22 AM
apwatson50's Avatar
Did you have the flywheel turned? Air in the slave-master cylinder.
Old May 17, 2005 | 11:48 AM
joefarmer's Avatar
Is this a stock clutch? If not, the pedal may just need to be pressed down further than before. I had the same issues with my pulling clutch. I ended up just adjusting my seat forward and that fixed the problem.
bnradnon.
Old May 17, 2005 | 09:36 PM
BigBlue's Avatar
There's no air in the clutch line. We didn't bleed it but it was full before and after the change and it's working great. The flywheel was turned. Not on a lathe but with a flywheel grinder. It seems to be getting a little better as we drive it. We need to change the fluid in it and see if that helps. So far it's holding great. Thanks for the help yall.
53 willys
27
May 14, 2008 06:26 PM
JimmieD
Oct 15, 2006 08:24 AM
kwhite4
May 9, 2005 03:22 PM
