checking line pressures
Old Feb 8, 2005 | 05:58 PM
seabee's Avatar
ok i here that a tc and valve body is ok if there is no internal leakage and you need to check the line pressures to make sure of this . so how do i check this
Old Feb 8, 2005 | 06:23 PM
Rganser's Avatar
scanner
Old Feb 9, 2005 | 11:37 AM
seabee's Avatar
ok will the snap on scan tool do this or do i need to take it to a dealer
Old Feb 9, 2005 | 08:00 PM
j-fox's Avatar
If you understand the auto trans, just use a gauge on the ports on the right side of it.
Middle port is angled forward and is the line/ accumulator port. This will show the pressure you want to raise/check. Then you need to go to the front port and it needs to be with-in 3-5 psi of the middle one.
Middle port has pressure in drive.
Front port has pressure in 2and 3.
Best to get a manual and the best is the Factory service manual.
0-300 gauge is good.
There is a lot more that gauge reading will show.
O.T
Sep 18, 2007 12:50 PM
toupee
Jun 27, 2007 04:19 PM
mr T
13
Mar 16, 2005 01:48 AM
SjLingenfelter
15
Dec 20, 2004 02:07 AM
mcevins
Jul 9, 2003 08:16 AM
