changing to bigger injectors
im currently running 150 injectors and wanting to go bigger will my stock turbo hold up till i can afford to buy one. and also what would be a good turbo to go to im looking at the bd super b special and the industrila injections phat shaft.
What 150 sticks do you have now? I would think your already pegging the pyro with your fuel now, I would think you should need some more air before fuel. What kind of temps do you see at WOT?
well there actually edge nozzles but im usually at 1000 to 1200 but i dont hold it to the floor very often at noraml driving i stay around 5 to 600. the reason im wanting to no is im looking at some 230 ddps.
His Pryo is pre-turbo. Brandon doesn't get in it too much.
Those 230s will get hot. And you will not like a bigger turbo running on 3.54s (er what gears do you have?) driving around Evansville.
here is my recommendation for you:
Get your adrenaline in and we will load a file that defuels based on EGTs
Put those 230's in
Get some gears that match those big tires. I know you have that under control.
Look at getting the BD Super Special it is a 64/71/14.
Or get a matching on from II.
Call me if you have any questions about anything.
Put those 230's in
Mlucas
Jun 6, 2008 12:34 PM
Eskimo
14
Jul 30, 2004 10:51 PM
boughtadodge
17
Jun 29, 2003 06:28 PM
