Carter P/N please.....
I am going to install a pusher pump in the near future and would like to know what part number Carter (or other) pusher is used for the CTD application. I have been around the horn and haven't had any luck finding this. <br> <br>Want to buy one at the local Napa.<br><br>Thanks Much,<br>Sned.
Re:Carter P/N please.....
Thanks for pointing me to the links. I'm just not real crazy about buying online or sight unseen. I'm one a them touchy feely kinda guys who likes to look things over before I hand over my hard earned. I will buy a pump online if I can't find what I need locally, I figure buying locally is much cheaper too. <br><br>If I do buy online what would I expect to pay?....$150 to $200??<br><br>Thanks,<br>Sned
Here is a link to Jeg's, The Silver pump is the one that guys are using, $72.99...
http://www.jegs.com/cgi-bin/ncommerc...mp;prmenbr=361
All you need to provide is connections between the pump and the stock fuel lines. I would say your down the road for less than $100...
HTH,
HTH,
Personally I would only buy an LP from a Cummins dealer. I have purchased 6 or so 4601's from NAPA/Jannetty and they were not long lasting although this last one (NAPA) is doing much better. They do have a 1 yr warranty but the local NAPA got tired of seeing me and finally said no more :'(. I will not be putting on as many miles as I was since I have a new off the road job so I would say this pump will last longer as it has only been on for a few months now and pressures are holding normal.
[quote author=ATEAV8GN link=board=7;threadid=14453;start=0#136206 date=1052412353]<br>Here is a link to Jeg's, The Silver pump is the one that guys are using, $72.99...HTH,<br>[/quote]<br><br>Thanks, there is a Jegs pretty close.<br><br>Copenhagenjunkie.....I gave up dip Feb. 8th WOW....it was hard to do but do-able. Dipped 30 years.
gsdog1
Mar 6, 2004 08:49 AM
crabman
Jun 2, 2003 06:21 PM
