Cargo Lights
Old Mar 28, 2008 | 11:12 PM
DodgeCowboy's Avatar
DTR's Cow Boss
Cargo Lights
Any one ever added a switch in line with the cargo lights too turn the power on rather than turning the dial on the dimmer because some times I am hooking up too a trailer in the dark and don't like having the dome lights up too be able too use the cargo light. I would like too do this so I don't have too turn the dome lights on to use the cargo light. I have a fsm and I am looking at the wiring diagram for the cargo lights but don't got a clue were too add the switch and do I need to run another fused power leg too the switch?
Old Mar 29, 2008 | 08:42 AM
DTR's Cow Boss
bump ten letter limit
Old Mar 29, 2008 | 09:27 AM
XLR8R's Avatar
Since the cargo light is low amperage, you should be able to wire in a toggle switch from a convenient voltage feed (such as from the fuse panel behind the access panel on the driver's side of the dashboard, visible when the door is open) directly to the power wire for the cargo light - should be under the driver's side A-Pillar trim, especially if you have the sliding rear window.
Since the OEM light switch won't be turned to a different position, there shouldn't be any voltage backfeed to illuminate the dome light. Just to make sure, you could jump a wire from the 12+ source to the cargo light feed before you install the toggle.
Old Mar 29, 2008 | 09:33 AM
DTR's Cow Boss
Hey thanks so I need too run a power source too the switch then a leg spliced too the cargo lights correct? I have my fsm but these things are code too figure out on the wiring stuff. How do I determine which wire is the right wire by looking at my fsm.
*edit*
After following page numbers from the wiring diagram on the splices I found one I aint looked at yet and I see this on the main splice wire that leads off the cargos. PK=pink wire correct?
Old Mar 29, 2008 | 10:04 AM
XLR8R's Avatar
Just take a minute to pull the cargo lamp assembly and ascertain the color-coding.
Old Mar 30, 2008 | 08:24 AM
FarmBoyAggie's Avatar
I have my cargo light wired to come on with the reverse lights and I have a seperate switch to turn them both on without putting the shift lever in reverse. It took some creative wiring and a switching relay because the cargo light is a ground switch system and the reverse lights are a hot switched system.
Old Mar 30, 2008 | 08:52 AM
DTR's Cow Boss
So what if I am just wanting too turn the cargo lights on with a switch from the cab so I don't have too turn the dome lights on what would have too be done too achieve that? Looking at my fsm I t think the wire is pink
Old Mar 30, 2008 | 04:45 PM
haloman's Avatar
What about getting a back-up light kit? Seems like it would give you more light than the cargo light?
Old Mar 30, 2008 | 04:51 PM
Bigdogbandal's Avatar
run a hot wire to a toggle switch and cut the pink wire. run that to th other side of the switch. If you come thru GA sometime look me up and I can wire it in about 15 minutes.
Old Mar 30, 2008 | 05:55 PM
the.hogman's Avatar
There is a post on this site that tells how to switch the wires on the dash switch. Cargo lights come on first and then the dome. Do a search to find it.
03CTDCO
Mar 6, 2010 10:48 PM
Asher
Feb 15, 2009 10:27 AM
ehammett
13
Dec 30, 2008 05:20 PM
steelblitzkrieg
Aug 28, 2007 10:07 PM
RickCJ
Apr 18, 2006 06:43 AM
