Can what I have make 500hp on the dyno?
Old Aug 12, 2009 | 01:35 PM
Brendan's Avatar
That is the question? with the mods I have can I tune the truck to put down 500 rear wheel horsepower on the dyno?
Old Aug 12, 2009 | 02:01 PM
clowndodge01's Avatar
I highly doubt it, 500 is asking alot more than what you have
Old Aug 12, 2009 | 02:55 PM
dodgetrucker75's Avatar
i read i little while back, on DDP's web site, that the 3's(or 90hp's) are only good for 500hp, so your chances dont look good...
Old Aug 12, 2009 | 03:01 PM
mainiac's Avatar
i agree. a properly tuned and turned up 180 and larger sticks will be necessary. the special has the air though.
Old Aug 12, 2009 | 03:12 PM
gwhammy's Avatar
I would think with a 0 or 100 plate and some more timing it would get real close to 500. I don't know anything about the turbo you have. If you have a stock extra plate grind a 100 and see if it makes a difference. What kind of boost are you making at the setting right now?
Old Aug 12, 2009 | 04:00 PM
Brendan's Avatar
I am seeing 42 pounds of boost at peak, and the special is wastegated at 45 psi. I have a zero plate to put in, and with the monster delivery valves and the 180 pump that should be getting me close shouldn't it? If not 500 then what do you think?
Old Aug 12, 2009 | 05:13 PM
kas83's Avatar
75 hp DDP's are good for 500, stock 215's have come close a couple of times. Definately tune it, throw some 4k's in it, and some more timing.
Old Aug 13, 2009 | 06:18 AM
gwhammy's Avatar
When I had a 12 valve I ran a 0 plate but liked the 100 plate better. The flat plate seemed to over fuel to much and kind of kill the spoolup. 20 degrees timing seemed to be a real good combo with 4000 governer springs. I sure miss the way it ran compared to the vp trucks I have now. Man it was sweet from 2500 to 4000 with the twins.
Old Aug 13, 2009 | 08:39 AM
YOUNG GUNS15's Avatar
eric at toxic diesel only has 90 horse injectors and he is above 600hp
Old Aug 14, 2009 | 12:53 PM
Brendan's Avatar
How far can I go with the timing before I won't like how it starts and runs? 17.5? 20? besides a fuel plate and delivery valves, how do I get my pump to flow more fuel? Is it high flow lift pump time?
Old Aug 14, 2009 | 03:40 PM
BigErksG2's Avatar
I'd try 19* There is no exact cut off where you like vs. wont like it and my opinion might not match yours on starting and running but I like 19 very well.
Old Aug 15, 2009 | 08:50 PM
Big Blue24's Avatar
To hit 500+, your going to have to add larger injectors or get more fuel out of your current injectors via longer duration. Late fuel from longer duration will create a lot of extra heat and smoke for every additional horsepower added.
To make more power with your current setup, you need to modify your AFC to allow full rack travel, add a 2095 rack plug, and increase your timing so fueling starts sooner. If your 3kgsk is defueling before 3000 rpm, you might want to add a click or two to the GSK setup to allow for a few more RPM. You don't want the governor cut fueling before you reach peak hp.
Old Aug 15, 2009 | 10:05 PM
white250005's Avatar
I have mine timed at 20 right now. I runs awesome, has a pretty good lope at about 1300 rpms sounds cool.
Old Aug 18, 2009 | 04:58 PM
Brendan's Avatar
Big Blue, I am not schooled on the rack plug modification, could you explain some more please? I had assumed that the fuel plate and governor springs are what controled fueling.
Old Aug 18, 2009 | 05:06 PM
the rack plug allows a couple more milimeteres of travle to the fuel rack, but to be able to use one, you will need a heavly modified (or removed) fuel plate and afc...
