can u stack these
Old Oct 4, 2006 | 02:48 PM
OGDAWG0680's Avatar
can u stack these
alrite i got the edge ez module in my 2001 24 valve and i was wondering if u could stack the new edge juice for the 01's with the attitude monitor???
Old Oct 4, 2006 | 03:31 PM
blackdiesel's Avatar
Registered
No, the double timing of both boxes together will make your truck run like crap/not run at all
Old Oct 4, 2006 | 04:09 PM
STACKED's Avatar
mine runs better with double timing, so i say its possible.
Old Oct 4, 2006 | 04:16 PM
Charlie8301's Avatar
Two timing boxes = no good. Also I think both the ez and the juice would both need to be plugged into the data port, so you couldn't physically plug them both in
Randy
Old Oct 4, 2006 | 04:49 PM
Diesel Dummy's Avatar
Different manufactures maybe, but two edge products wont work, they use the same connecting points. Now you could use the edge you have and another box(superchips,(smarty in a class by itself),hypertech) that just uses the obd port in the cab will probally work. Some people use a lot of timing but i personally think it is not good. A good combo is the edge and the smarty, the smarty allows you to just add fuel or add just timing or even both.
Old Oct 5, 2006 | 03:52 AM
2whistlers's Avatar
NO, you cannot stack 2 timing BOXES. You can stack a timing box and programmer which sometimes do the same thing.
Old Oct 5, 2006 | 09:57 AM
Ph4tty's Avatar
If you want the juice then you can sell your ez here in the dtr classified section
Totallyrad
Jul 19, 2011 07:41 AM
white250005
Oct 25, 2007 10:19 PM
smoky beast
Oct 18, 2006 06:58 AM
B.Law
16
Apr 22, 2005 02:28 PM
Cat Cracker
Jul 14, 2003 12:17 PM
