can this programmer be stacked?
Old Apr 12, 2010 | 08:27 AM
blue_bandit's Avatar
Talking can this programmer be stacked?
Hey everybody, i was just wondering if anyone has been successful in stacking a box with the superchips max micro tuner, and what have you stacked it with? I recently installed a raptor 100 and am looking for a bit more go. Also, does the superchips programmer adjust timing and fueling or just one of them? Thanks in advance.
Old Apr 12, 2010 | 10:35 AM
sheriffav8r's Avatar
I have my Superchips stacked with an Edge Juice w/ Attitude. I wrote Superchips to find out if it adjusts timing but got no response. I have the wastegate removed and hooked closed and the funny thing is when I have nothing installed (stock programming and Juice on 0) I can hit 29-30 psi. When I have the Superchips on HI-PERF and Juice on 0 I can only hit 26 or so psi. So the Superchips limits the boost through its programming more than stock does. I definitely like having the Superchips stacked with the Juice but don't know how the two are interacting as far as pump timing goes. But it does make the truck move FAST, though.... With the Superchips on HI-PERF and the Juice on 3x3 I can easily spin the rear wheels and on 5x5 it is pretty impressive! I'm trying to limit my boost though until I can make sure my recent head job has all the kinks out of it. I'm staying below 35psi but I hear that with ARP studs and a stock gasket I should be good up to about 50psi. I think wide open on 5x5 I could only make 40 psi with my little HY-35.... The main reason I use the Superchips, though, is to adjust my tire height....
Old Apr 12, 2010 | 10:59 AM
johnyb59's Avatar
Something that is fuel only. TST, FMS, Xzilliraider. Something along those lines.
Totallyrad
Jul 19, 2011 07:41 AM
goose2w1
Jun 14, 2007 09:55 AM
morkable
Feb 15, 2007 10:23 AM
TorqueJunkie
18
Aug 30, 2006 11:51 AM
thecatsfan
Feb 11, 2004 01:58 PM
