Cam Question
Old Feb 15, 2005 | 10:13 PM
K2Cummins's Avatar
Cam Question
Is it worth it to have a cam installed at my current power level?
Aside from the cost what are the pros and cons?
Thanks
Old Feb 15, 2005 | 10:33 PM
K2Cummins's Avatar
Also, who's cam would you all recomend?
Old Feb 15, 2005 | 10:47 PM
PourinDiesel's Avatar
There are several out there.
Depends on what you want out of the truck.
Check www.scheiddiesel.com (click on pickup truck pulling) and www.piersdiesel.com
Both of those shops are top notch.
Old Feb 15, 2005 | 10:49 PM
Don M's Avatar
DTR Advertiser
Cams usually wont add much power. You can certainly extend the power band, move it around some, or fatten the curve up.
Adding a cam is a nice addiiton for smoke control and a fatter powe curve at lower rpm. Almost like having a faster spooling turbo.
Rip will have a line on my cams in the next few months. Less costly than some of the options out there and the cam is not a regrind of a used stock cam. Its a brand new casting that I have ground to specs.
Don~
Old Feb 16, 2005 | 12:57 PM
K2Cummins's Avatar
Hey Don,
What are the benefits of your cams, do you have any real world mileage reports and general feedback from testers that you can talk about?
Old Feb 16, 2005 | 01:54 PM
Don M's Avatar
DTR Advertiser
I will have everything in the next 2 months. Specs and all. So far there is limited test data, but a few guys are trying them now. Some are pretty hot!
Don~
Old Feb 16, 2005 | 02:04 PM
K2Cummins's Avatar
Thanks Don
etn550
Apr 1, 2010 12:12 PM
AH64ID
Jan 18, 2009 04:59 PM
Brendan
Dec 11, 2006 12:26 AM
Ram of Steel
Jun 12, 2006 09:41 PM
