cam gear instalation?
Old Mar 27, 2008 | 04:51 PM
somis13's Avatar
how is the drive gear on the cam shaft held in place? is it pressed on? is their a key way? should I replace the gear when replacing the cam?
Old Mar 27, 2008 | 05:25 PM
MikeR's Avatar
Yes it is pressed on, and yes there is a keyway. I see no reason to replace the cam gear.
Old Mar 27, 2008 | 05:37 PM
Troutstrannysvc's Avatar
Pressed on, keywayed.
You can also heat the gear up to 400-450' and itll fall right on.
Old Mar 27, 2008 | 07:06 PM
afoulk's Avatar
If your putting a performance cam in, you might wanna think about a bolt on cam gear if your planning on any high rpm work, especially with a p-pump.
Old Mar 27, 2008 | 11:17 PM
thekidfan's Avatar
Yes, and if you over heat it (more then Cummins spec, as you are suggesting) it may just fall right off!
Old Mar 28, 2008 | 02:06 AM
HOHN's Avatar
It might not be too good for the heat treat, eh?
Old Mar 28, 2008 | 04:40 AM
Fishin2Deep4U's Avatar
Be careful heating gears. But, it's an easy process.
As mentioned, if you are changing the cam, might want to consider that bolt on gear.
I have pressed a few off and on. Also heated a couple. I prefer the press, but you have to be careful.
Dave
Old Mar 28, 2008 | 06:35 AM
I doubt it'll go anywhere from the retainer I have holding it on...
And Greg Houge who designed the Max Spool cam said to take it to that.
Old Mar 28, 2008 | 10:00 AM
somis13's Avatar
who makes a cam that requires a bolt on gear?
Old Mar 28, 2008 | 10:28 AM
MaxSpool, and Helix camshafts
Greg Houge and Don M. Greg makes Max Spool, Helix's are from Don
Shcieds too...
Old Mar 28, 2008 | 11:11 AM
Mcmopar's Avatar
Scheid makes them both ways.
Old Mar 28, 2008 | 11:49 AM
Helix Cam Shaft
MaxSpool
I went w/ the Max Spool due to availability more than anything.
They aren't producing Helix's as far as I know for a little while they just sold the last one out of the batch not to long ago IIRC.
MaxSpool is a regrind, Helix is not.
Scheid can make both ways I think, I'm pretty positive John_P is running a cam from them.
Originally Posted by Don M
Wait for the 8620 SAE gas-carburized, Billet Steel cams. Should be ready in a month or so. Super strong, hard as hell lobes ( 60+ rockwell ) and basically unbreakable. Pricing is very competitive. No bushings need to be installed in the block. Direct drop in. Will run on stock tappets as well. No billet tappets needed.
:rockwoot:
<--- Don M.
hope this helps
Old Mar 28, 2008 | 02:36 PM
I have not seen the retainer that his cam uses, but keep in mind a part that is designed to have a press fit should retain that even with a bolt.
There is a procedure offered in the Cummins factory manual and I would recommend anyone doing this defer to the proper procedure for your truck. It just eliminates a potential issue.
Dave
Old Mar 28, 2008 | 08:53 PM
Mcmopar's Avatar
Yup, me too.
Old Mar 29, 2008 | 06:18 AM
logskidder's Avatar
Cummins shop manual 3810206-02 page 1-32 "heat the camshaft gear in a preheated oven at 149* C (300* F) for 45 minutes. The oven should never exceed 177* C (350* F) or the gear will be permanently distorted. From the boys who built it
