building my own trans
Originally Posted by BigBlue
Those double deeps are a heavy piece of art. Oh, piece of advice. Don't dump the fluid from your current trans pan into the double deep before you install it.
Besides, I'm going to use Dexron III (or whatever the number is now
) instead of the ATF+3 thats in it now.
Well I suppose you don't HAVE to have a billet input shaft, but it was HIGHLY recommended. There is a LOT of stress put on the input shaft with an e-brake and there is just too much inconsistancy with the stock input shaft. I was told that the stock intermediate and output shafts would be fine unless I started to push some serious hp/torque and/or did a bunch power braking (like in drag racing, etc.) or sled pulling. I plan to add some more power later, but nothing too radical since this is still my primary vehicle and I use it to tow my gooseneck (which is why I eventually want the e-brake).
well i put the converter in saturday, but it was raining and i have no idea how much of a differance it made. took it out sunday morning and popped the turbo fist thing so. i will have to wait till i get a better turbo set up on it before i start beating on it.
as in a set off ddp4s and a stock turbo are a very bad match, spools very quick. as in quick enough to break the exhaust wheel off the shaft cause general mayhaem. i need to get a holt of jr and get my 55 pronto.
Got another package today..... 12 more pounds of goodies for the tranny. This box looks to be the master kit (all the clutches, steels, gaskets, bushings & seals), direct update kit, OD update kit, billet front servo & HD spring, billet accumulator, 4.4:1 servo arm..... blah blah blah. I'm sure the valve body, vb install kit and torque convertor will be showing up any day now.
OK, potential stupid question but............. I was under my truck tonight after work looking at all the various thing I'll need to disconnect in order to drop the tranny, making sure I can get to all of them, etc. etc. Just for grins, I decided to drop the inspection cover for a look see. Here's the question: how in the heck do you get to the TC bolts? 'cause you can't get to them through the inpsection cover like every other auto I've worked on in the past. I did notice an access cover on the passenger side below the oil/water heat exchanger and just above engine barring hole. It looks like it was pretty much in the arc of the TC bolts, so is that the access hole for them?
