boot on fuel shut off
Old Oct 12, 2005 | 02:08 PM
isissound's Avatar
I was adjusting the fuel stop plate and when I was taking apart the afc housing the rubber boot on the bottom of the fuel shut off solenoid looked like it ripped or jest came separated from the top is this a problem and if so where can I get another
Old Oct 12, 2005 | 02:19 PM
cumminsdriver635's Avatar
Mine came off, and i am not worried about it. I dont thinky ou can buy a replacement anywhere for cheap. Just go ahead and pull it on off if it is ripped bad, or it may get caught between the rod, and the solenoid, and make it not work right. I have been running without mine, and so has my uncle for a while now with no problems. As long as it doesent start rusting/getting bound up it should be fine. It moves in and out enough, it shouldnt build up rust, but if it does, i will just pull it out and sand paper it.
Eric
Old Oct 12, 2005 | 07:09 PM
infidel's Avatar
Without the boot or with a torn one crud and rust will eventually cause the solenoid to hang up. You can buy one here www.fostertruck.com or do what I do and use a section of 1.75" bicycle inner-tube with two cable ties.
Works just as well as the stocker and lasts longer too.
Old Oct 13, 2005 | 09:07 PM
Rockyhud's Avatar
Ditto!
I agree totally with Bill as I did the same thing this past summer and it's worked great. And a lot cheaper too.
Steve
Old Oct 14, 2005 | 09:09 AM
isissound's Avatar
thanks i think i am going to jest buy the boot
Old Oct 14, 2005 | 09:42 AM
DustyRock's Avatar
I have a pic in my gallery of the solenoid witht the new and old boot.
Might want to see what a new one should look like.
Old Oct 15, 2005 | 11:25 PM
isissound's Avatar
thanks man
dkimmel
Jan 3, 2011 10:54 PM
mt72916
Mar 13, 2009 05:50 PM
randyswelding
Feb 9, 2009 10:40 PM
95black2615
Oct 8, 2008 03:34 PM
Dean Snow
Sep 26, 2007 03:40 PM
