boost port for gauge
Old Jul 31, 2003 | 12:04 AM
DynamicalyUnstable's Avatar
Where is it on my 2001? The website I found an install for said it was 3/4 pipe thread but the plug I found in mine is closer to one inch! It definately had pressure so I don't know what's up. Please help!
Old Jul 31, 2003 | 07:36 AM
TXRAM2's Avatar
Re:boost port for gauge
It is the 3/4" pipe plug on the drivers side of the engine between the fuel filter and the fire wall. The 3/4" pipe plug is actually a little larger than 3/4", but that's is the correct size. You will need a 1/2" square drive to remove it.
There are other ways to tap into the boost. One of our vendors here sells a replacement bolt that is tapped (can't remember who at the moment) and you can also tap the air horn.
hth
Old Jul 31, 2003 | 11:46 AM
HeberRam's Avatar
Piers Diesel Reasearch sells a tap as mention above for the Boost gauge:
http://www.piersdiesel.com/index.htm
Steve
Old Jul 31, 2003 | 05:14 PM
sdscuba's Avatar
What should stock boost be at WOT?
I'm seeing 17psi
Old Jul 31, 2003 | 05:58 PM
DPG's Avatar
DPG
17 psi is close to normal stock pressure. I got just a hair over 20 on my gauge before I got an EZ.
DeWain
Old Aug 1, 2003 | 09:32 AM
Diesel Dave's Avatar
I used to get around 18lbs before I added my EZ. Now I get around 30lbs ;D.
Old Aug 1, 2003 | 09:37 AM
TXRAM2's Avatar
yep 19psi on a hard pull while stock
Katmandu
Nov 10, 2008 03:18 PM
scout98
Jul 26, 2007 12:13 PM
QWKRTNU
Sep 26, 2006 10:22 PM
