Boost Gauge install
Old Oct 31, 2006 | 07:27 PM
Devin_01's Avatar
Boost Gauge install
Yeah was just wondering were the best spot is to tap in for installing a boost gauge???
Old Oct 31, 2006 | 07:31 PM
Big Smoky's Avatar
I just drilled and tapped my intake horn. I was the easiest place to get to and it works great.
Old Oct 31, 2006 | 07:35 PM
bostiguy's Avatar
I used a threaded port that's located toward the back of the head behind the fuel filter. Just needed an adapter and removed the plug and replaced it with my gauge fitting. No drilling or tapping required.
I can't remember the specifics but a search will find you what I'm refering to, or someone more knowledgable will chime in....
Old Oct 31, 2006 | 07:40 PM
Big Smoky's Avatar
I know my old 12v had the threaded port that I used, but I couldn't find one on my '02. Are you talkin about a 12v?
Old Oct 31, 2006 | 07:48 PM
Devin_01's Avatar
No I have a 98.5 24valve. The Kit i got has a tee fitting in it. Should i use that or should i go into the port??
Old Oct 31, 2006 | 07:57 PM
Charlie8301's Avatar
or you could use a boost bolt
http://www.dieselmanor.com/dm_products/Dm-DBF.asp
Randy
Tank_66
Feb 28, 2008 08:34 PM
latitud_rt
Mar 24, 2003 11:31 PM
DawgII
Mar 10, 2003 07:15 PM
soundfetish
Feb 26, 2003 02:37 PM
