boost
boost
I have a 99 with a edge programmer, 4 inch exhaust and big turbo outlet from banks, and a cold air in take. Planning on bigger injectors like 100hp units should i think about a bigger turbo, a boost fooler or what? thanks
Probably already need to turn up the stock turbo just with what you have (I used a boost elbow) unless your edge is just an EZ. If it is an EZ 100hp sticks are IMO perfect for a turned up stock hx35. I have to work to hit 1100 preturbo on mine set up that way.
Fill in your sig!
Fill in your sig!
if your 'edge' taps the pump you will want more air. if it is a non-pump tap box then you may be ok - only driving it will tell . . .
i can peg my egt's pretty easy with my 100 stix and the programming turned up . . . and i have a 62.65.14 turbo
HOHN
45
Oct 8, 2005 08:51 AM
triplenickel
Aug 23, 2005 04:01 PM
GTSDave
Jul 8, 2005 09:06 AM
Palmetto_kid
Jan 16, 2004 02:21 PM
