Bhaf
Old Mar 18, 2005 | 11:25 PM
Txwelder's Avatar
Bhaf
So I go around looking to find the filters by part number, I have 15 part numbers and nobody has anything in this town. Guess I have to drive to Phoenix or San Diego to get one. My question is, with as many tractor dealers in this town, what application does the BHAF fit. If I could go to John Deere or Case and tell them I need a filter for Tractor X, what would I tell them. I get my Fleetguard filters from them with no problem so can they fill the air filter void I have? Thanks!
Old Mar 19, 2005 | 12:09 AM
Dr. Evil's Avatar
In most cases you have to get them to order it in. When I go to Cummins...they usually dont have them on the shelf.
Fleetguard AH19037
NAPA 2790
WIX 42790
Donaldson B105006
Baldwin PA2820
Hastings AF1012
AFE 20-40044
Carquest 87790
John Deere pmah19037
Big A 93790
Caterpillar 3i0005
Fleetrite ahr819037
Luber-finer laf2531
Fram ca6818
UNI 908
Old Mar 19, 2005 | 06:26 AM
boostedte37's Avatar
I went to napa and got mine they had it in stock for $38 I have a pic in my gallery The part # is 6637
Old Mar 19, 2005 | 07:41 AM
jman's Avatar
boostedte37, what did you do to tie the filter to the truck, ??????? to keep it from floping around.
thanks ,jman
Old Mar 19, 2005 | 07:46 AM
Dr. Evil's Avatar
make a heat shield (template in tech facts section)....or just use a bungee cord
Old Mar 19, 2005 | 07:57 AM
out_drsman's Avatar
You can also order them online from TST.
moparguy's Avatar
Jman, the filter to turbo pipe is rigid enough that the filter will not move around. Be sure to either drive the 3 mounting studs for the factory filter housing down through the fender, or pull the rubber fastners from the factory housing (cut the closed end off) and install them upside down on the studs.
Also, cover the AC line near the firewall with a piece of split 5/8th heater hose or garden hose to keep the filter from wearing it.
Last of all, I highly recommend a 2" long piece of 4" muffler tubing as a stiffner in the filter.
Good luck, RJR, Daddy of the BHAF
Old Mar 19, 2005 | 08:15 AM
SmokinFive9 4x4's Avatar
Which is bigger the 6637 or the 2790?
Old Mar 19, 2005 | 10:26 AM
jman's Avatar
"I highly recommend a 2" long piece of 4" muffler tubing as a stiffner in the filter."
where would this tubing go , in the hose where the clamp is??????????
jman
Old Mar 19, 2005 | 10:28 AM
jman's Avatar
Oh and I forgot , what about water on the filter?????
jman
Old Mar 19, 2005 | 12:25 PM
Lil Dog's Avatar
Get the marine version of the BHAF and then you don't have to worry so much about the water problem. The filter media is not paper.
The stiffener tube must be for some specific brands. Mine is soo thick at the neck that there is no need for a "stiffener". Its stiffer than the original filter housing..
I got mine at NAPA and is the 542790 by Duralite, Marine version.
I have a pick in my gallery..
J-eh
Old Mar 19, 2005 | 02:23 PM
phox_mulder's Avatar
I heard something somewhere, probably here, but the Marine version isn't the best choice.
They are made for damp conditions, not dusty.
Marine version doesn't filter the dust as well as the non marine version.
Something to think about.
phox
Old Mar 20, 2005 | 02:11 PM
Lil Dog's Avatar
Well, I will have to run some oil analysis to make sure..
Thanks for the tip..
J-eh
Old Mar 20, 2005 | 05:16 PM
Wolff's Avatar
I went with the WIX 42790 and had a heatshield cut out of aluminum. I just need to order my pre-filter. I used a short 4" piece of exhaust pipe to stiffen it up.
Old Mar 20, 2005 | 11:37 PM
MARKY MARK's Avatar
SmokinFive9, I have the 6637 and it is smaller than the 2790. Someone has a picture in their photo gallery but I can't remember who it is.
Mark
