Bhaf
Old Aug 17, 2004 | 04:17 PM
SjLingenfelter's Avatar
Bhaf
Which one is cheap but is still worth it? Which one would you get?
Fleetguard AH19037
NAPA 2790
WIX 42790
Donaldson B105006
Baldwin PA2820
Hastings AF1012
Old Aug 17, 2004 | 05:01 PM
Shootist's Avatar
I believe it's the Baldwin that I buy for $28 at a trucking supply in Albuquerque. Beats the NAPA by almost half. Also, I'd be surprised if Baldwin and Fleetguard weren't manufactured by the same folks...the filters and labels look identical.
Keith
Old Aug 17, 2004 | 05:06 PM
MnTom's Avatar
FYI The NAPA filter just cost me $58 and change.........
Old Aug 17, 2004 | 05:18 PM
Ok cause i have a O Reilly's and Napa and an autozone near me. Would they have all of them?
Old Aug 17, 2004 | 05:21 PM
jiMMyCTD's Avatar
napa should
Old Aug 17, 2004 | 06:40 PM
rattle_rattle's Avatar
Just paid $51 at NAPA.
Old Aug 17, 2004 | 07:41 PM
MnTom's Avatar
What are you complaining about? I paid more that you.
Old Aug 17, 2004 | 08:08 PM
jrs_dodge_diesel's Avatar
I paid about 50 at a Cummins place for a Fleetguard.
Old Aug 17, 2004 | 09:02 PM
4doogie's Avatar
well i paid $45 for my NAPA filter, man i got ripped
Old Aug 17, 2004 | 10:11 PM
kandgo's Avatar
What do you all use for the moisture protection?? What is the diameter of pipe do you all use to keep the filter from crushing at the seal?? I have a guy who wants to try one and I have only seen one in use. Thanks and Goodluck,,,Rick
Old Aug 17, 2004 | 10:42 PM
Mechanos's Avatar
I use the Fleetgaurd AH19004.... it's the marine version of the AH19037. It's waterproof, but it's a little spendy at $135.
Old Aug 17, 2004 | 10:55 PM
kandgo's Avatar
Did you make a heat shield for it?? Is it a renewable filter as in clean and oil?? Thanks,, Rick
Old Aug 17, 2004 | 11:15 PM
ilvdslsmk's Avatar
i used the napa and put the outerwears on for water protection, it works pretty good too
Old Aug 18, 2004 | 06:15 AM
Commatoze's Avatar
Originally posted by kandgo
What do you all use for the moisture protection?? What is the diameter of pipe do you all use to keep the filter from crushing at the seal?? I have a guy who wants to try one and I have never seen one in use. Thanks and Goodluck,,,Rick
I use an Outerwears too. It's amazing how much stuff is caught by the it. My filter looks practically new. As far as a support collar. Depending on which brand you buy, you may not need it. The one I have has a hard plastic collar. If you need an interface, a "DWS to Drain 3"x4" Reducer" should do the trick.
Old Aug 18, 2004 | 07:24 AM
Palmetto_kid's Avatar
call them
write the numbers down on a piece of paper. Call the 3 stores and see which ones they have, and write the prices down. Stand back, and see which price is the best. Go buy the cheapest one becuase they are all the same.
thats what I did. Its a simple, yet highly effective plan.
The cheapest one I found was at a small, mom&pop parts house in Sweeny. it was like 31 bucks.
