Best performance box for 24 valve?
Old Jun 5, 2005 | 12:46 AM
Intercooler's Avatar
What is the best performance box out there for the 24V and where do you get it? Costs how much?
Old Jun 5, 2005 | 03:32 AM
95ram's Avatar
It all depends on who you ask. This question will more than likely start something.
I have a TST Power Max 3 which is adjust able with remote. I like it because it is fueling only. Others like the Edge ez which is timing only. Others like the Edge comp which is adjustable and adds timing and fueling. The TST is available with a compition. The edge comp available in as a drag comp. While others like Van Aaken. Some like Bully Dog. The hot new thing is the MAD ecm.
Old Jun 5, 2005 | 04:04 AM
DodgeDog's Avatar
Check into the F.M.S. (fuel management system) from Blue Chip Performance. I believe it is the best overall box out there. Plus I stacked it with an Edge best combo I have had experience with. http://www.bluechipdiesel.com/
Old Jun 5, 2005 | 11:45 PM
MadDog01's Avatar
Intercooler, theres lots out there. The Edge Ez does timing and fueling and maybe fuel pressure, not sure about the pressure part. Most people that are using the Edge comp are very happy with. You can leave it on level 1 and not tap the Vp wire and it is the same as an ez. I've heard good things about Mad ECM. You can brouse around and find links on the different set ups. Just do your research before you buy. The sky the limit if you have the money!
Gary
Old Jun 5, 2005 | 11:52 PM
2500CTD's Avatar
There are actually 2 versions of the MAD ECM, one with use with a comp and the other with out. I'm saving for a tranny, then I'm getting a MAD, then prolly a redline box, dunno yet still deciding but definatley getting a MAD ECM.
Old Jun 6, 2005 | 06:28 AM
KennyM's Avatar
Intercooler,
My 99 had the Edge comp box. I think I paid around $600.
Old Jun 6, 2005 | 08:42 AM
CTD NUT's Avatar
Gary
Injector pressures are not variable on a VP44 regardless of the fueling box used.
For ease of install and the most power and adjustability for the money, my vote goes for the Comp.
Old Jun 6, 2005 | 08:44 AM
caleb c.'s Avatar
Drag Comp is sweet!
04ctd
Oct 5, 2006 08:27 PM
wdbates
Jul 5, 2005 10:34 AM
Hoss
23
May 17, 2004 04:05 PM
vince1
Jun 6, 2003 12:22 AM
