Best 1.5-2" front lift for 2500?
Old Mar 7, 2007 | 10:59 PM
dweller's Avatar
I've looked at all the designs, pretty simple, really. Just wondering which ones everyone has had good luck with?
Thanks
Old Mar 8, 2007 | 01:11 AM
tollboothrichie's Avatar
revtek, bulletproof and nice hardware
Old Mar 8, 2007 | 01:48 AM
Big Smoky's Avatar
My spacers are made by Top Gunz Customs. I like them and have had no problems.
Old Mar 8, 2007 | 08:19 AM
TxDiesel007's Avatar
my truck has a skyjacker 2.5 inch lift
although it looks stock height to me, and well its been nothing but problems with the dual shock brackets, they break at least once every three or four months, ive had to reinforce them.... id avoid skyjacker for ur lift, why do i have it? it came with the truck...
Rick
Old Mar 8, 2007 | 08:42 AM
Diesel-Dan's Avatar
Cant complain about my Hell Bent Steel 2" Kit....BUT i am going to build some 1" longer control arms when i get my welder up here....with adjustable lower arms for Caster......Hope this will keep tire rubbing to a min......
Old Mar 8, 2007 | 08:54 AM
MSquare's Avatar
I went with custom built coils from www.coilsprings.com. They look better then D25's and perform great.
Old Mar 8, 2007 | 09:33 AM
RowJ's Avatar
Also happy with Hell Bent 2". Very stout!
http://www.hellbentsteel.com/dodge/dodge-lift-kit.html
2" longer coil springs are the 'top drawer' way to go... but spacers work well too.
RJ
Old Mar 8, 2007 | 03:00 PM
floridadieselki's Avatar
the hell bent spacers work really nice, my dad had them on our 01' ctd before he sold it. they are a strong spacer, you cant beat them for the money.
Old Mar 8, 2007 | 04:06 PM
Redline Ram's Avatar
hell bent steel here too, not too bad to put in either.
Old Mar 9, 2007 | 11:18 PM
1stGen545's Avatar
I just put my Top Gun Customz.com 2" spacers in about 2 hours ago. They were $79.99 and have a life time warranty but doubt that I well ever need it as well as they are made. I will make my next set (3") but these are great. They look just like the Hell Bent ones. I also plane to make some new arms with different end's to get more flex.
Old Mar 9, 2007 | 11:38 PM
Muddin_dude06's Avatar
Exactly how hard is it to make new control arms? Do you just need to use DOM tubing or something with a strong design and simply take the length of the stockers and add 1" to all of them? There isn't any more geometry or anything more involved in that? I am contemplating getting some 2.5"-3" longer coil springs or spacers and new control arms would probably be a good idea, lol.
Old Mar 9, 2007 | 11:49 PM
1stGen545's Avatar
DOM or Cromoly tubing. Make the upper adjustable. If you are a good welder/ fabricator its not to bad. You realy dont need longer arms unless you go over 2-2.5" lift.
Old Mar 10, 2007 | 03:43 AM
Marine's Avatar
Veteran: Marine Corp
Speaking about spacers...does anyone have their stock spring foam and hardware they want to get rid of? I am taking out my blocks and like an idiot, threw the stock stuff out.
I will offer to buy them.
Thanks!
Old Mar 14, 2007 | 11:07 PM
dweller's Avatar
Thanks for all of the responses. Marine, why are you reverting to stock?
Old Mar 14, 2007 | 11:09 PM
oaborbag's Avatar
I have a 3" leveling kit and the tires rub the back wheel well, i'm guessing its because the stock arm's aren't long enough for this high, anyone know of a good cheap fix?
