BD-Power super b
Old Aug 29, 2007 | 08:48 PM
rhino 660's Avatar
Question BD-Power super b
getting a super b from a buddie it was on an 04.5 any reason it wouldent bolt up to my stock manifold and would piping still work? thanks
Old Aug 29, 2007 | 08:55 PM
dieselrob's Avatar
It will fit just needs some tinkering with, and a down pipe they use the v band clamp. You will have to reclock the turbo( tinkering) so it lines up with piping.
Old Aug 29, 2007 | 08:59 PM
cyric's Avatar
It will bolt right up to your manifold and the outlet to the intercooler will be the same. The only thing you are gonna need is a new down pipe eithe an hx-40 style or a 3rd gen style depending on what the turbo has on it.
Joe
Old Aug 29, 2007 | 09:01 PM
rhino 660's Avatar
i forgot to add it comes with the down pipe and air intake
Old Aug 29, 2007 | 09:09 PM
2whistlers's Avatar
Joe
Unless these turbos are different, then the outlet to the intercooler will not be the same. The 3rd gens outlet has the 90 degree on the compressor housing already where as the elbow for the 2nd gens are not made onto the housing, but are a seperate piece altogether. On my old Aurora 2000 that was made for a 3rd gen, I had to make an elbow to make the outlet mate to the intercooler tubing.
Old Aug 29, 2007 | 09:11 PM
Carp's Avatar
You may need to finess the oil drain pipe a little around the wastegate actuator as well. With the downpipe, the install should go smoothly. Good luck.
Old Aug 29, 2007 | 11:31 PM
IntakeRacing's Avatar
just have a lot of freaking patience.... it won't be as simple as some make it out to believe. you will be on it all day, and i had to cut and weld the dp to make it work.
Old Aug 30, 2007 | 05:40 AM
schoust's Avatar
Guy's while were on the subject I was looking at a super b special from Bd that I thought might work on my 12 valve but it was designed for a third gen truck,can I get it to fit? What would need to be done??
Old Aug 31, 2007 | 03:27 AM
they make a super b special for your truck:
1045120 Super B Special Turbo - 1994-2002 5.9L A Dodge 1,855.00
cdn catalogue
Old Aug 31, 2007 | 07:56 AM
schoust's Avatar
Yes I realize they do but somone I know has a third gen that they whnt to sell for a decent deal and I was wondering if it can be made to fit??
SlingShot
Apr 4, 2011 08:05 PM
Diesel Dave2
16
Dec 20, 2008 07:11 PM
bucknasty
Jan 21, 2007 10:12 AM
Buckshotmckee
Apr 19, 2005 07:20 PM
SjLingenfelter
29
May 17, 2004 10:40 PM
