Banks Wastegate problem!!!
Old Jun 21, 2006 | 06:59 PM
Dusty Ratcliff's Avatar
well I got my new (used) turbo today, only to find the wastegate is busted up!! (check the pic in my gallery, is pending as I type) seems like I can't win for losing anymore, was wondering if anyone had seen this happen before & worst case scenario are there any other sources for a wastegate??? this turbo came with the power elbow & I'm gonna have to buy a $150 downpipe to make it work, now I'll be darned if the freakin wastegate isn't all jacked up!! I really don't have the $$ to buy either one right now, but looks like I have no choice, cuz my stock turbo needs bearings (the comp wheel is rubbing the housing) I guess I can use the guts from this new turbo & just stick the stock (JUNK!!) 12 cm exhaust housing on it for now until I can figure out where to go from here!!!! any ideas???????? thanks, Dusty
Old Jun 21, 2006 | 07:15 PM
12valve's Avatar
what turbo did you get?
hmmm waiting for the pics!
Old Jun 21, 2006 | 09:33 PM
pics are up now, & the turbo is just a stock HX35 +the Banks housing & "power elbow" or whatever it's called, take a look & see what ya think????? Dusty
Old Jun 21, 2006 | 09:42 PM
Bob Wagner's Avatar
does the diaphram have a hole in it?
Old Jun 21, 2006 | 09:53 PM
dunno, could you tell by just looking????? I haven't put it on the truck yet, not sure if I want to with it looking like that??? how is the best way to check the diapghram???? thanks, Dusty
Old Jun 21, 2006 | 09:56 PM
Bob Wagner's Avatar
I would clean it up and use an air compressor to check the diaphram operation. get it all strighten up first. its not that bad, must be road salt or
need to check it before you install it
Old Jun 21, 2006 | 10:01 PM
the problem I was referring to was the split in it, the head on it is pulled away from the piece that the two nuts are on, if you look a little closer you can see it, there shouldn't be a gap between the two, I should have gotten a pic. of the "good" side too, sorry, check it out again & see if you can tell what I'm talking about, thanks, Dusty
Old Jun 21, 2006 | 10:05 PM
Bob Wagner's Avatar
that is no big deal, just it it back into shape. all should be fine.
Old Jun 21, 2006 | 10:08 PM
but will it stay, it looks like the sheet metal is torn/ripped or whatever you wanna call it????? so I doubt bending it back will keep it there????? I'm afraid that it will continue to tear its way on around the whole thing until it's completely ripped apart???? any ideas? thanks, Dusty
Old Jun 21, 2006 | 10:48 PM
G-NOTE's Avatar
Talking
Get someone with a mig on very very very low amps to through a couple of tack welds once you bang it back on...
Or just JB it...
Old Jun 21, 2006 | 11:06 PM
torquefan's Avatar
Have you checked the dimensions of your old wastegate actuator to see if they're interchangeable? It'll probably fit just fine. You can buy those from Dodge, and probably Cummins. Sure, it's not the "Banks Big Head", but you can still adjust the rod for whatever maximum boost you want, and you'll never know the difference.
Old Jun 22, 2006 | 12:16 AM
getblown5.9's Avatar
i feel terrible because im the one who sent him the turbo, it wasnt damaged when i packaged it up, so apparently the fine boys over at fedex did a heck of a job on the handling part.
i would check to see if the stock style WG will bolt back onto the housing, because all the big head does is stay close until 37psi, which you could make a stocker do that with a boost elbow
BigWaylon
Dec 22, 2009 05:23 PM
sallyman1
Feb 10, 2008 06:17 PM
HawaiiCTD
23
Jan 16, 2008 11:33 PM
ataboy9026
Feb 22, 2006 05:09 AM
MoparRiggan
Oct 13, 2005 11:54 AM
