ATS Hybrid Turbo
ATS Hybrid Turbo
My new ATS Hybrid Turbo (WH1C 14cm,58mm compressor) arrived Thursday morning and I couldn't wait to install it. I took a couple of hours from work to install it. Everything fit perfectly and installation was quite easy. After several miles to give it some break in time I tried it out and Wow! My egt's have decreased as much as 300 degrees under full acceleration and the power is amazing! I'm thinking about putting my HY-35 on a lawn mower because it will never be on my truck again. Just thought you would like to know about this turbo. Thanks Don and ATS!!! ;D ;D ;D ;D ;D ;D ;D ;D
Re:ATS Hybrid Turbo
Sounds good!<br><br>How does the boost and egts compare before and after the install?<br><br>Any difference in "turbo lag"?<br><br>What other turbos did you consider?<br><br>Thanks<br><br>George
Re:ATS Hybrid Turbo
George,
With the HY-35 my boost would top out at 19 lbs and with my comp box on 5x5 my egts would go to almost 1350 degrees. With the ATS Hybrid turbo by boost goes to 28 lbs and my egts top out at 1050 degrees. There is no difference in my spool-up but it seems that the ATS spins down more slowly. When running 60 m.p.h. my egts are about 500 degrees and it runs much lower at every speed.
I considered the PDR HX-35 also.
Re:ATS Hybrid Turbo
Jack ...<br><br>A hybrid is parts of different turbos combined to make a better turbo . or a specific application turbo .... like more air ... better spool up ... yee haw!
Re:ATS Hybrid Turbo
[quote author=Jack Thorpe link=board=7;threadid=11630;start=0#115452 date=1047571284]<br>Gotcha. Thanks. I was confusing that with a variable vein turbo. I don't know the name for that either.<br>[/quote]<br><br>Variable Geometry Turbocharger (VGT)
Re:ATS Hybrid Turbo
Stakeman,
I have about 1000 miles on my new turbo now and it seems to deliver the power more smoothly and seems a little stronger. On the highway this setup is difficult to stay under 80 mph when not hauling. Acceleration at 85 or 90 mph is as hard as from 50 or 60 mph. The best part is that my egt's stay at a very safe level! Would you consider putting the wastegate elbow that came with the comp box or is 28 lbs of boost enough on this setup?
Re:ATS Hybrid Turbo
I have been eyeing up one of these hybrids that uses a HX35 housing with a HX40 wheel, what are the advantages of this over my stock HX35? I assume it will make more boost, right? After I do the clutch I am planning on timing, 4K GSK, and injectors. What kind of power increase can I expect if I run a hybrid? <br><br><br>Thanks.<br><br>John<br><br>
