ATS Billet Flexplate can Fail
Old Feb 9, 2010 | 06:28 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Don't send it to Eric!!!! That is a trophy and should be hung on your wall
Actually letting them get a look at it can help them with their quality control and in the end help us all...... But be sure and keep a good photo of it so you can have bragging rights
Old Feb 9, 2010 | 06:38 PM
Porscheman87's Avatar
Eric, Yes the factory ring was retained on install and I am sure it was installed correctly as it was done by Rich Ellis at Ellis Performance Chicago area who built the truck. I would be interested in shipping it to you for an exchange, I was really not expecting anything since it is 1 year old +, very impressed that you are offering, was quite suprised at the failure of the part.
Pm me for further discussion on this offer, thanks
Rob
Old Feb 9, 2010 | 07:24 PM
Eric @ ATS's Avatar
PM sent! I'm about as surprised as you are, and knowing that the factory ring was correctly reused has only made me more curious.
Lary's exactly right that it can only help assure that this was an isolated incident, and while it's unlikely it could also provide insight on other unknown issues with the vehicle itself & maybe help prevent a larger issue. Either way, a few bucks to ship it in is well worth it!
John, I'm happy to chime in over here any time I can be of help, I just wish I had more time to post in general!
Thanks to you guys for giving us the chance to work this out (although I wish I'd known BEFORE Porscheman87 spent money on another one!)
Old Feb 9, 2010 | 09:16 PM
Pictures of ATS Flexplate
Eric, and all other interested DTR members here are the pictures of the ATS Billet Flexplate
Rob
Attached Thumbnails ATS Billet Flexplate can Fail-img_0725.jpg   ATS Billet Flexplate can Fail-img_0724.jpg   ATS Billet Flexplate can Fail-img_0727.jpg   ATS Billet Flexplate can Fail-img_0726.jpg
Old Feb 9, 2010 | 09:46 PM
madhat's Avatar
Administrator/Jarhead
Dang it, boy!
Old Feb 10, 2010 | 08:05 AM
patdaly's Avatar
Porsche, you may want to check runout of the flexplate in the installed condition. I would get the truck up on the lift, and use a dial indicator on the ring gear. The last time I saw one break like that, the trans was not square with the block, and was flexing the flexplate.
Not saying you have a problem, but from the looks of that failure, flexure, not a bad hunk of material, etc. would be my first inclination.
Old Feb 10, 2010 | 11:39 AM
I will check that radial runout this weekend, but this is the only thing that failed, with a runout that bad to tear the center out of a solid billet flexplate would it not also damage the converter and the pump? It had no vibration or anything noticible prior to the failure, and replaced it with the BD flexplate and it is back running like it did prior to the failure. Dave Goerend also told me to check for that when I talked to him on it, so I will definately be checking that ASAP
Old Feb 10, 2010 | 12:05 PM
patdaly's Avatar
Since it lasted a year, I would say it wouldn't be anything gross enough to cause a noticeable vibration. Not knowing the material, but betting it is 41XX series Chromemoly, small variations in runout would be bad.
This could get complicated given the fact that there is not much room to work, Could be rear crank flange, could be torque converter lugs not even, etc. I would first remove all the TQ attach bolts, push the TQ back away from the flywheel, and measure it unattached. Then repeat with it attached. Either case your runout should be pretty small with a aftermarket flexplate, typically they are held to very close standards. ATS should be able to tell you what they allow.
And yes, after all that, it could have simply been a small inclusion in the original flywheel material, even the best mills have some in their material......... But I would verify readings anyway.
eastmentCTD600
Apr 23, 2012 12:23 PM
barryp
18
Sep 15, 2009 03:30 PM
Spooler
33
Oct 15, 2008 04:47 PM
Ilikebikes
Nov 10, 2007 02:10 AM
SuperDave4x4
16
Oct 4, 2006 12:08 PM
