ARP studs and valve covers
Old Jul 20, 2006 | 10:26 PM
one54ton's Avatar
I am almost done putting these pain in the Edit in. Ive cut 2 little notches the the front of the valve cover. Do I need to modify the back or will it fit?
Old Jul 21, 2006 | 02:43 AM
rockjeep73's Avatar
I didnt have to modify my valve cover at all. were the studs in the front to tall?
Old Jul 21, 2006 | 07:59 AM
one54ton's Avatar
Well they tapped the cover in front just a bit. I know I put the right ones in the right places as well.
Old Jul 21, 2006 | 11:04 AM
caleb c.'s Avatar
I thought the 12v's only had clearance issues? Mine Fit perfect with no cutting...
Old Jul 21, 2006 | 11:14 AM
Jetpilot's Avatar
The 24v motors should not have a valve cover issue using the ARP studs..... Did you bottum tap all of the holes in the block? Are these ARP studs or A1?
Doug Smith
Old Jul 21, 2006 | 02:12 PM
one54ton's Avatar
No, they are arp's and Im positive they are all the way down. Well I found out the back fits fine. This seems sort of weird. I need to check some things.
pwrtripls1
Mar 10, 2011 12:12 PM
rebal
Sep 7, 2009 06:33 PM
Ramrod90
Apr 30, 2009 12:16 PM
West Coast
Nov 6, 2006 07:53 PM
DieselJoe
32
Mar 16, 2006 09:35 AM
