Any one running out of fuel fast on a draw straw?
Old Sep 12, 2009 | 10:23 AM
tx02's Avatar
So i did a draw straw and holly blue pump on my 02 cummins yesterday and ive herd lots about fuel problems running out at 1/4 tank. So me and a buddy pulled the sending unit apart and gutted it. I ran a 1/2 return back in to the canister and cut the draw straw in half, put a piece of rubber 5/8 hose in between it and back in to the drawstraw. I ran all this down into the pick up canister, i can run this truck bone dry with not one spuder or 1/4 tank problems. Works wonders for those of you that have problems with this!!
Old Sep 13, 2009 | 03:13 PM
sold it's Avatar
i have had no problem with mine an have been way lower than a 1/4 but it depends were u put it and how far from the bottom you leave it
Old Sep 13, 2009 | 06:32 PM
nickg's Avatar
reason you dont run out of fuel is, most of the 1/4 issues with draw straws is that they/we have a 100+GPH pump that circulates so much fuel. Your holly wont run out cause it aint moving any fuel, and likely you dont have a return fron the holly back to the tank.
as an example I had an AD fail on me last yr and plumbed my stocker back in where the AD was and I had NO fuel pressure drops or 1/4 issues, put the AD back in and If I stop hard or fast with less than 1/4 my Edge will beep and I have fuel pressure drops
my 2 cents
77machomopar
Oct 7, 2009 02:50 PM
tanderson2002us
13
Apr 24, 2009 10:26 AM
atc250r
Nov 11, 2008 05:15 PM
00' Quad Cab
Sep 27, 2006 01:27 AM
