Amsoil users
Old Mar 5, 2003 | 10:28 PM
ARAcummins's Avatar
Amsoil users
I was just wondering what kind of oil and filter change intervals you guys are running, little confuse with some of the stuff I have read, I think it was getting way over my head.<br>Heath
Old Mar 5, 2003 | 11:25 PM
Edward's Avatar
Re:Amsoil users
I change the filter at 7500 miles and add two qts, of oil to top it off then change the oil and filter at 15000 miles.
Old Mar 6, 2003 | 12:58 AM
NAIL BENDER's Avatar
Re:Amsoil users
I'm just starting a new program of changing filter and quart at 5000 and oil and filter at 10000.
Old Mar 6, 2003 | 05:50 AM
Dieseldude4x4's Avatar
Re:Amsoil users
Change main filter every 5000. and the bypass filter every 25000 miles. Change oil every 25000 or depending on oil analysis results. Using 15 W 40 HD Marine Diesel oil.
Old Mar 6, 2003 | 05:53 AM
boehunter49's Avatar
Re:Amsoil users
??? Hay I change oil an filter at 7000 at the price of the oil there is no better protection for your engine than good clean oil. If it costs you $100.00 to change your oil every 7000 miles that comes to about $ .014 cents per mile THATS CHEAP PROTECTION at least to me it is.<br> That is ...014cents PER mile not even 2 whole cents. Do it right change them both.<br> Bob
Old Mar 6, 2003 | 06:03 AM
Re:Amsoil users
??? HAY, thats cool. I got a friend here at work that changes his every 3000 miles which to him is about once a month with the miles he drives. I personally don't like laying under my truck that much and am getting the same protection for the same cost or less with the filter system I have. I can also change my filters out in five minutes or less where I have them located and I'm done till the next time. <br><br>I ran my old 89 up to 60000 miles on the same oil and it was still good when I drained it at that mileage. Got the test results to prove it and can fax them to you if you would like to see them. The truck is still running and has not been touched and had 142000 hard miles when I traded it. I kept that oil and ran it through two of my cars till it was all gone finally. You have people from both ends of the spectrum here so you have to run what makes you feel good.
Old Mar 6, 2003 | 07:02 AM
hellotbone's Avatar
Re:Amsoil users
I change mine every 5000 K I think that should keep me pretty safe.
Old Mar 6, 2003 | 07:08 AM
Re:Amsoil users
[quote author=Jamie Attridge link=board=7;threadid=11858;start=0#112302 date=1046955773]<br>I change mine every 5000 K I think that should keep me pretty safe.<br>[/quote]<br><br>Yep, that should do it.<br>Do you have the preferred customer set up?
Old Mar 6, 2003 | 07:32 AM
Bulldozer's Avatar
Re:Amsoil users
Change mine every 5000miles with Mobil Delvac 15w-40 I figure for $27 an oil change why not keep it changed.
Old Mar 6, 2003 | 07:45 AM
turbospl311's Avatar
Re:Amsoil users
I use the 15-40 Marine Amsoil and change filter every 5k and change the oil based on analysis. So far after 52k miles, 1 change at 40k just because I couldn't wait any more. The oil analysis was still great.<br><br>Don Miller<br>97 2500, 16 deg tim, Scotty II, 3k springs, #8 plate......<br>INjectors cmoming from Piers (hopefully today), new 4&quot; from Rip on Monday.
Old Mar 6, 2003 | 08:16 AM
Re:Amsoil users
[quote author=turbospl311 link=board=7;threadid=11858;start=0#112320 date=1046958333]<br>I use the 15-40 Marine Amsoil and change filter every 5k and change the oil based on analysis. So far after 52k miles, 1 change at 40k just because I couldn't wait any more. The oil analysis was still great.<br><br>[/quote]<br><br>Yeah, mine was still good at 60000 but I figured that it didn't owe me a thing at that point.
Old Mar 6, 2003 | 10:42 AM
ridofpwrstroke's Avatar
Re:Amsoil users
I run 10W40 amsoil and I change the filter at 5,000 and oil and filter at 10,000. I called amsoil awhile back and they said if you change it more your wasting money. The oil is not even close to need changing.
Old Mar 6, 2003 | 11:41 AM
ARAcummins's Avatar
Re:Amsoil users
how much does it cost to run that oil analysis? I am currently running rotella 15-40, and have been wanting to switch but it sure ain't cheap, and I could not find it anyway last week. However sitting here doing the math I would only have to run 25000 on a oil change to be money ahead, and then you add the protection on top it's starting to look like it well pay for itself in the long run. Does anybody know of the easiest way to get amsoil and that by-pass filter setup??<br>Thanks<br>Heath
Old Mar 6, 2003 | 11:45 AM
Re:Amsoil users
Try to find an amsoil catalog or dealer. The remote bypass filter is in there. My neighbor is a dealer and I got one from him.
Old Mar 6, 2003 | 12:07 PM
Ruralmedic's Avatar
Re:Amsoil users
According to Amsoil, both the 15W-40 HDD &amp; marine, and the series 3000 5W-30 HD diesel oil can have change intervals up to 2 times the engine manufacturer's recommended change interval, or six months, whichever comes first. Intervals greater than that can be used if supported by used oil analysis reports. If using Amsoil's SDF full-flow oil filter, it is recommended to change that every 7,000 miles or six months on a diesel engine. If using another manufacturer's oil filter, follow the engine manufactuer's guidelines for changing filters.<br><br>Other than being more expensive and a 30 wt. oil, the series 3000 claims to offer better fuel effciency over the 15W-40. <br><br>I'm currently running the Amsoil 15W-40 in my truck since early November and only have about 6K miles on it. I use the Fleetguard Stratapore filter, it's less expensive than an Amsoil SDF and is approved by Cummins for this engine. I've changed the filter once so far at 3K miles and added make-up oil. I will end changing at 6 months, unless I go with an oil analysis report. <br><br>Bottom line; it's good motor oil, but you're not going to be saving any money using it. If cost is not an issue, there are other quality synthetics out there as well, such as Mobil Delvac 1 which is readily available over-the-counter. A lot of dino-based motor oils have been proven of extended drains in the Cummins as well. It's a darned good engine. Just because I use Amsoil, doesn't necessarily mean it's the best.
