airtex fuel pump installation
Hello all:
Has any one had any experience installing a airtex E7153 supply pump? I am installing this pump on a 1999 built 10/98 24v 5 speed. The inlet fitting comes straight out the back of pump,it almost hits the firewall,let alone installing the quick connect. Any ideas?
Don H
Don H
vzdude
Thanks for reply.
I might be calling this by the wrong number. The number on the box is (Delphi) FP953,The instruction sheet reads (E7153 diesel fuel pump replacement instructions) maybe E7153 is the old pump. The new pump uses the original outlet fittings but the inlet is a straight brass quick connect fitting connected to the pump by what looks like special threads with a O ring seal. The end of the pump is nylon. The new pump extends to the fire wall a good 1.5 to 2 in further than the original.
Don H
Thanks for reply.
Don H
84mphcdt
May 24, 2009 11:38 PM
southtx813
Feb 13, 2009 08:49 PM
