Air Valve Extensions for Dually
Old Oct 9, 2002 | 11:22 AM
RacingD98's Avatar
Replacing tires all around within the next few days and would like to find air valve extensions to make life easier when it comes to checking pressures and refilling. Anybody got recommendations on where I may find these?<br><br>thanks
Old Oct 9, 2002 | 11:39 AM
TPilaske's Avatar
Re:Air Valve Extensions for Dually
I just picked up a set of these from camping world... haven't had a chance to get 'em on yet. Will probably do it this weekend. They look like they should work out real good! ;D<br><br>Tony
Old Oct 9, 2002 | 11:46 AM
Monty's Avatar
Those that TPilaske showed, should work just fine. Stay away from the .99 cent Wal-Mart specials. I tried a set from them and took them off about as fast as I put them on. Cheap chrome plated plastic, and they leak air.
Old Oct 9, 2002 | 02:12 PM
Mule Skinner's Avatar
I have used the same extensions from camping world. Had to install steel valve stems, the weight from the extensions on the rubber stems was too much. With in a month or so had flat tires and had to change.
Old Oct 9, 2002 | 02:39 PM
TPilaske's Avatar
[quote author=Horse Hauler link=board=7;threadid=5711;start=0#50404 date=1034190749]<br>I have used the same extensions from camping world. Had to install steel valve stems, the weight from the extensions on the rubber stems was too much. With in a month or so had flat tires and had to change.<br>[/quote]<br><br>That's good too know, I will have to get steel valve stems installed first! Thanks for the tip! ;D
Old Oct 9, 2002 | 07:30 PM
CoastalDav's Avatar
Camping World also has the other type extensions without the hoses which make it easy to reach with an extended length<br>air chuck. They should show them on the web site at <br>www.campingworld.com<br><br>Dave<br>Melbourne, Fl
VACHZHD
0
Aug 9, 2014 10:43 AM
LFD2037
Apr 22, 2009 03:22 PM
MX429
Jul 17, 2006 07:08 PM
BERZERKER
Jul 19, 2004 08:18 AM
Mopar_Mudder
Jul 16, 2003 09:10 PM
