AIR DOG questions
Old Apr 25, 2009 | 04:40 PM
NKYGuy28's Avatar
AIR DOG questions
I am going to upgrade to an airdog system. I plan on running 500- 600hp, do I need to buy the 150 or the 100 pump. If I go with the 100 do I still have to use the draw straw and have the 1/4 tank issues, if I go with the 150 and use the vulcan draw straw is that the best set up to go with or does it already come in the kit?
Old Apr 25, 2009 | 05:35 PM
scottsjeeprolet's Avatar
Get the 150 and it comes with the draw straw and everything you need.
the best way without a lift is to remove the bed. If you drop the tank make sure to set it on 2x4's where the straps touch the tank. then drill the hole and cut the straw to length.
Old Apr 25, 2009 | 06:05 PM
Fishin2Deep4U's Avatar
The DSII is the DrawStraw that you are referring to. We have customers that can draw teh tank down to nothing with no issues, so it will work if installed correctly.
If you want a sure fire fix, get a DrawStraw I. It still need to be installed correctly, but everything goes into the module bucket. Our fittings also bring all the return fuel from the engine and the bypass from the AirDog and put it back in the bucket. No issues with this setup at all.
Dave
Old Apr 25, 2009 | 06:15 PM
NKYGuy28's Avatar
Dave I was actually talking about the drawstraw I. I have been trying to decide if everything I was reading was right and you just confermed it. I am going to order the 150 with the drawstraw I.
Thanks alot for the info.
Old Apr 25, 2009 | 09:52 PM
Gotcha.
Dave
duster75
Sep 9, 2009 11:02 PM
trailinone
16
Jun 19, 2009 04:28 PM
herb
Jul 18, 2008 08:25 AM
ModManiac
16
Mar 28, 2008 11:31 AM
