Air compressor
Old Nov 26, 2002 | 04:26 PM
ridofpwrstroke's Avatar
Air compressor
Just put on a York style compressor on. Just letting anyone who is interested that it is a real easy installation and it really flows air. At 1500RPM's, it is supposed to flow around 8 cfm. The kit uses a york compressor and it bolts right over your alternator. It is only for 24 valves. Very nice setup. Now I can run air tools and fill up tires anywhere.
Old Nov 26, 2002 | 06:31 PM
shortfieldbreak's Avatar
Re:Air compressor
That's pretty slick. I'd like one of those. It'd solve that stuck-on-the-road-in-the-middle-of-nowhere-with-an-underinflated-tire problem I've been worrying about. Sometimes I get a little lazy about checking the tire pressure , but getting better since I got that neat little radio shack digital tire pressure gauge to play with. ;D ;D<br><br>-SFB
Old Nov 26, 2002 | 07:03 PM
Ryan's Avatar
Re:Air compressor
Pictures would be great. I have been debating/putting off/spending on other BOMBs the air compressor idea since I got my first truck.
Old Nov 26, 2002 | 07:43 PM
phox_mulder's Avatar
Re:Air compressor
And it will come in handy for the air horns which should be on every deisel powered truck on the road ;D.<br><br>Where did you get it, if I may ask?<br>Link?<br><br>thanx<br><br>phox
Old Nov 26, 2002 | 09:20 PM
pilotmdurst's Avatar
Re:Air compressor
does it come with a storage tank ?<br>does it bleed off the moister automaticly or manual?<br>and i agree it should be standard for air horns to blast all the non-drivers out there!
Old Nov 27, 2002 | 06:56 AM
jfpointer's Avatar
Re:Air compressor
I have no idea if this is where ridofpwrstroke got his, but this place sells mounting/installation kits, plus the tanks, fittings, compressors, etc.<br><br>http://www.onboardair.com/<br><br>I have no affiliation with them, etc. They also have some reference info about York compressors that looks like it would be helpful in finding one in a junkyard somewhere.
Old Nov 27, 2002 | 11:29 AM
Re:Air compressor
That is the exact place where I got my kit from. I put a sanden compressor on my other truck from kilby. I saw this kit and I installed it. I see there are a few people interested so here is everything. I got the kit at Kilby enterprises which is onboardair.com, the kit is 150 bucks and it comes with a new pulley for the alternator, a pulley that mounts to the bracket, a bracket, a small v-belt, and a longer serpentine belt. It comes with all the hardware. The instructions suck. It kept me guessing. The job took me 4 hours and if I did it again, it would take me an hour. You have to go to a junk yard to find the compressor or you can buy one from him. These york compressors are a dime a dozen so buy one from the junkyard. He has all the specs on what you have to measure to get one. The only problem I ran into is that you have to have a nippendenso alternator. I had a bosch and I tried to make it work. It will not align properly. I went to the junkyard and bought a 99 nippendenso. The only difference between the alternators is the plug in on the back. The bosch has a plug in type and the nip has bolts that you hook up wires. I just tapped the line and made two eyes and hooked up. The compressor has fittings and I hooked them up to the tank. I dont know if the compressor can pump out 200 psi, but i think it can. I dont have any pics but I can take a digital pic and post it. The key part is removing the bracket that holds the alternator on. The kit comes with a new bracket. Any more question, just ask.
Old Nov 27, 2002 | 11:30 AM
Re:Air compressor
You might also want to buy the flange fittings from kilby. Make sure to also get a pressure switch.
Old Nov 27, 2002 | 01:16 PM
hellotbone's Avatar
Re:Air compressor
Thanks for the info guys I dropped brad a line there at onboard air to see what he can fill me in on. <br><br><br>
Old Nov 28, 2002 | 02:48 AM
Edward's Avatar
Re:Air compressor
Now does anyone know where we all can find a set of air horns off a GE locomotive?
Old Nov 28, 2002 | 08:48 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:Air compressor
Where else......www.trainhorns.com ;D
Old Nov 28, 2002 | 08:57 AM
PistolWhipt's Avatar
Re:Air compressor
Someone has a set in the Classified section under the Misc. header. If you got 600 bones !!<br><br>PISTOL
Old Nov 28, 2002 | 09:25 AM
Re:Air compressor
Here is a gawdy way to mount them ...IMOA<br><br>http://www.dodgeram.org/rides/08/matt_d/rail_horns.htm<br><br>PISTOL
Old Nov 28, 2002 | 09:42 AM
Shovelhead's Avatar
Re:Air compressor
[quote author=PistolWhipt link=board=7;threadid=7589;start=0#73356 date=1038497115]<br>Here is a gawdy way to mount them ...IMOA<br>http://www.dodgeram.org/rides/08/matt_d/rail_horns.htm<br>PISTOL[/quote]<br><br>I'll bet you'd only snooze at a light in front on him one time...... <br>Then you'd have your own freshly installed sunroof, and a cleaning bill for your seat covers.
WhoCares79
Jun 3, 2008 11:45 AM
Camarogenius
Jun 25, 2007 08:55 PM
SRTchris
Feb 25, 2007 06:29 PM
JKM
Mar 8, 2006 03:23 AM
