Aimco rotors
Old Nov 22, 2002 | 08:38 AM
bulthisl's Avatar
Re:Aimco rotors
Hauler ;<br>I got mine in Frankfort at NAPA for $33 and change.<br>I didn't see having the down time at that price.<br>Plus it wasn't much higher than having them turned.<br>Or buy new ones , have old ones turned and hold on to them for next time.<br><br> : Eddie : 8)
Old Nov 22, 2002 | 09:56 AM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Re:Aimco rotors
CH, I would go with the new ones too. The rotors they make today are not as beefy as they used to be. Seems like you turn them once and then hit a water filled pot hole while they are hot, and instant warp.
Best insurance when lil hauler is aboard anyway!
Old Nov 22, 2002 | 12:15 PM
Dieseldude4x4's Avatar
Re:Aimco rotors
Don't forget, you will most likely need inner and outer bearings and races as well as grease seals. Be careful driving in the new races, that can ruin a bearing before you even put it on the road. Use a good quality hi temp wheel bearing grease too. Don't ever tighten, that will smoke them quick.
Old Nov 22, 2002 | 12:18 PM
Rammin On's Avatar
Re:Aimco rotors
Sealed unit bearing on the 4X4 ......
Old Nov 22, 2002 | 01:22 PM
Re:Aimco rotors
Coolness, post the pics when you get a chance. I was use to my old 89 where you have to tear everything apart. Have not had the occassion to tear down this one yet and hope it will be a long time before I do. Is that why there is no periodic greasing required on the 3500'S?
04ctd
Aug 3, 2007 04:19 AM
towin1JT
14
Oct 29, 2003 08:51 AM
Scubasteve
Sep 3, 2003 08:19 PM
stoneman
Sep 1, 2003 07:49 PM
Madoco
Aug 13, 2003 09:42 PM
