AHHHH
Old Sep 23, 2003 | 11:17 PM
dodgeman01's Avatar
AHHHH
I can't figure whats wrong. I put a 4k gov kit in my truck and 370 injectors and my truck has a steady lope at 1800 rpms. I have messed with the gov springs to get the lope at one spot instead of all over the rpm range. what is going on???
DM01 >
Old Sep 23, 2003 | 11:52 PM
dsljunkie's Avatar
Re:AHHHH
Mine had a lope after I put the gov spings in and at first I thought it was cool 8), but the coolness quickly wore off >. All you need to do is back off the gov spring keepers 1 click, maybe 2. Mine had a pretty good sized lope at 1200-1400 and 1 click put an end to it . I would go 1 click at a time. Also you may have to adjust your idle after loosening the keepers because it will probably slow down. That is if you dont like it to idle low 8).
Scott
Old Sep 24, 2003 | 09:03 AM
dodgeman01's Avatar
Re:AHHHH
My springs are on the 1ST click. any looser and they would fall off should i take the small middle spring out?
DM01
ABDTR #5
Dec 16, 2007 08:31 PM
06Cummins
19
Mar 18, 2007 10:54 PM
turbox2
Mar 30, 2006 11:36 AM
Commatoze
Jul 9, 2003 12:57 PM
