aftermarket torque convertor question
Old Sep 16, 2006 | 10:38 AM
RickCJ's Avatar
I have a customer who just had an aftermarket tc installed in his truck. The tc lock up clutch engages very slugish and sometimes only when you leave off the throttle. I personally called the owner/builder and explained the problem with the convertor and he told me the tranny doesn't have enough line pressure to lock the convertor, but he told the truck owner this would work fine and that the trans. had enough pressure and he sold him this convertor.
Has anyone ever heard of an aftermarket convertor reguiring more pressure to lock the convertor? Something about the stator needing more force to engage the clutch! This trans has a shift kit and has close to 150 psi to the lock up. or is this BS?
I'm not talking holding pressure, this convertor doesn't slip once it locks.
Old Sep 16, 2006 | 11:25 AM
Geico266's Avatar
I believe he'll need a new valve body to go along with the TC. He definantly has line pressure issues.
Better call Dave Goerend.
Old Sep 16, 2006 | 11:27 AM
cumminsdriver635's Avatar
I have a transgo shift kit, and when my converter locks, it locks fast, and hard with no slipping. Sounds like he has a valve body problem of some kind.
Eric
Old Sep 16, 2006 | 11:48 AM
dzlfarmboy's Avatar
It could be a line pressure problem,or i once had a brand new converter from a company that wouldn't lock up unless you let your foot off the pedal. Something wasent right with the orfices in the converter, so a new one was put in,
Old Sep 16, 2006 | 12:57 PM
RickCJ's Avatar
Can you tell who's convertor? I see a DTT.
Old Sep 18, 2006 | 08:14 AM
dzlfarmboy's Avatar
No this was another truck i had a while ago Wasent a DTT.
Old Sep 18, 2006 | 12:27 PM
Mike D's Avatar
If the stator is too tight it could effect lock-up. He'll have to get a modified valvebody. Call Dave and explain the problem, he's the man.
I had a similar problem after installing a tighter TC. Had to let off the fuel for it to lock up. Bought Dave's VB and problem is gone.
Old Sep 18, 2006 | 05:25 PM
RickCJ's Avatar
He said the convertor would work with the valve body in his truck. He didn't want to change any thing but the convertor.
BIG_BLAZER86
Sep 24, 2013 08:51 PM
93dieselZak
Jun 16, 2011 06:10 PM
pw58
30
Mar 24, 2008 01:49 PM
wminmi
Jun 17, 2007 08:51 AM
NorthWestMatt
May 25, 2007 05:46 PM
