AFE Intake...
Old Aug 22, 2006 | 09:04 AM
CTDPower11's Avatar
AFE Intake...
Hey, I was wondering if anyone has an AFE intake... And what are some of the pros and cons, and do I need one???
Old Aug 22, 2006 | 09:43 AM
getblown5.9's Avatar
they are great, alot better than the K&N you have now. just dont oil the filter too much. i found out mine was over-oiled when i pulled the head apart and the intake manifold is full of oil residue
Old Aug 22, 2006 | 09:56 AM
RowJ's Avatar
If your K&N is a drop in filter, I would say you will get a lot more air, to feed your Juice, with the AFE. Their filters are probably the best on the market.
If you already have the FIPK II cone filter from K&N. I would stay with it. I'm one of the few here that thinks the K&N's are a good system. I had an FIPK II for 2 yrs and it worked very well. Never any oil or debris in the turbo throat or air intake tube, but I left it alone!
As stated above... biggest problem with K&N's is cleaning too often... and over oiling. Should be left alone for at least 50,000 miles, unless very dusty conditions.
If your asking about just the 'Torque Tube' intake... I don't see the need for it on our trucks.
Good Luck
RJ
Old Aug 22, 2006 | 11:41 AM
BARTMAN's Avatar
I now have the AFE Stage 2...awesome! Had the Stage 1, but liked the fully enclosed chamber of the 2.
Old Aug 22, 2006 | 06:54 PM
rebal's Avatar
If i was on pavement afe would be fine . but on dirt roads forget it I see way to much dirt !!I just installed an bhaf in the AFE shield
Old Aug 22, 2006 | 11:27 PM
Ph4tty's Avatar
Did you ever do oil analysis?
Old Aug 23, 2006 | 01:49 AM
AllonBlack's Avatar
Just put the AFE stage 1 on. Love it! Really makes the turbo scream and increased the throttle response. Can't beat it for the price either.
Old Aug 23, 2006 | 07:23 AM
RowJ's Avatar
Yes, at least every other change! No abnormal readings. Silicon, which everyone seems to concentrate on (when discussing K&N), was in the 4-7 ppm range, depending on how far I went. Got 10 ppm one time...on a 10,000 mile test with Amsoil, without changing fleetguard filter (part of the test).
Note
1-If unfamiliar with FIPK II, it has much larger cone filter than previous K&N models. Similar in size to PRO Guard 7.
2-Went to Scotty II; Sound & EGT's were better but oil analysis had no noticable differences.
RJ
Old Aug 23, 2006 | 07:28 AM
Jetpilot's Avatar
The AFE units are great! If you are worried about filtration levels of the standard filters try the progaurd 7 versions. As for the BHAF, you are better off wit the OEM unit. The BHAF looks cool but actually has been shown to decrease HP....
Doug Smith
Old Aug 23, 2006 | 01:14 PM
SSweeney's Avatar
Doug Smith
This seems contrary to most input on bhafs. Not to say your wrong but many think it is THE best for air filtration.
Old Aug 23, 2006 | 01:18 PM
4x4dually's Avatar
AFE Stage 2 A++++
I just put the AFE II on my truck along with a Juice/Attitude and absolutely love it. Turbo sounds awesome now and will sound even better when I finish my exhaust. I have the ProGuard 7. I haven't had it long enough to require a cleaning yet, but I think it is the cat's meow.
Old Aug 23, 2006 | 03:24 PM
Clayten's Avatar
DTR's Toad Wrangler
Doug Smith
Finally the truth is out.
Old Aug 23, 2006 | 03:34 PM
RowJ's Avatar
Maybe the BHAF filters too well.... for for the high air flow requirements of bigger HP??
Never used one so can't say.
RJ
Old Aug 23, 2006 | 05:32 PM
SSweeney's Avatar
How could a paper filter(bhaf) that size, affect negatively if air is whats needed. Do we have hard data on BHAFs. I wonder if these people against it sell air filter systems.
Old Aug 23, 2006 | 06:10 PM
Charlie8301's Avatar
My thoughts exactly, I've Had a K&N FIPK II for almost three years now, silicon levels alway between 3-5 ppm @ 4000 mile intervals. Never any oil in the intake tube or turbo. Were the people that had problems with K&N running the drop in or the FIPK?
Randy
