afc spring ??
afc spring ??
hi
i have done the mods to my afc, it has a 20 lb spring i think ? stock
if i dont do any thing else just replase the 20 lb with a 40 lb spring will that add or subtract fuel at low boost psi ?
i have some smoke at low to moderat boost 6- 12 lb ?
still tryin to figer it out !
was told one from a 215 unit would work , anyone have one they dont need to replace my 180 20 lb er ?
The stiffer the spring, the more delayed low end fuel you get. Like you say "subtract fuel at low boost". It's kinda like spinning the star wheel farther back.
I probably have a 215 spring laying around (they're very stiff).
Hey Mike what spring do you recamend in the 160 pump? I have done just about every Mod I possibly could on it except fooling with the springs in the Afc and screwing with the cams and Barrels which I would not do anyway. I sthere anything there to be had??
royta
Feb 15, 2005 10:15 PM
Dusty 96
Nov 5, 2002 01:45 AM
