adrenaline/smarty stack on dyno
Old May 27, 2011 | 09:11 PM
DieselRebel24's Avatar
hey fellas...dyno days are comin up here next week and i got the opportunity to use a quadzilla adrenaline and a smarty tuner to use. i was wonderin if anyone has done this and what would be the best tune on the quad and settin on the smarty to run? i have heard the smarty will make you lose 20 -30hp on the dyno....iv got the beta tunes loaded on the adrenaline...torq tune at the moment. anyone have any suggestions with the setup im runnin in my sig minus the xzilleraider bein unhooked and the adrenaline takin its place?
Old May 27, 2011 | 10:21 PM
HOHN's Avatar
You'll want to balance it out.
I would suggest using #2 onthe Smarty as your starting point. Anything higher than #4 will bring the fuel in so fast (with your big injectors and Adrenaline) that it will put the fire out and hurt your power.
With all the fuel you have, I'd suggest keeping it thin on bottom-- mild Smarty tune, Adrenaline tune that's softer on bottom.
Then bring in fuel fuel once you're up over 12-15psi or so.
JMO
Old May 27, 2011 | 10:22 PM
HOHN's Avatar
Oh, and your best tune will depend on what kind of dyno it is.
If it's a load dyno (Mustang or Superflow), then you can bring the fuel in harder and sooner.
But it it's a dynojet, you'll have to run a milder tune as it's a lot easier to put the fire out without serious load on the engine.
Old May 28, 2011 | 03:40 PM
its a mustang md-1100 dyno. the torq tune i have on it right now brings the fuel in hard in the bottom. so maybe run the smarty on like 4?
Old Jun 15, 2011 | 10:54 AM
2000 24v's Avatar
I have I quadzilla adrenaline that adds 180 hp and 420fpt have any tips for that
farmboykjb5.9
Jun 15, 2009 08:19 AM
sal3c
Sep 22, 2008 09:25 AM
01smoker
Mar 19, 2008 12:51 PM
Topper
Mar 3, 2008 10:17 AM
smokingoat
18
Dec 27, 2007 08:54 PM
