Adrenaline - lower boost than Comp?
Old Apr 21, 2008 | 06:56 PM
SilverSootXpres's Avatar
I tried reading what I could off the beta testing thread, but it's so long.
I've had the adrenaline in for a couple of weeks now, and my boost at WOT is only at 40psi. With the comp is was 46-48psi. What would make it drop?
Also, it is hard to tell if there is more power on stages 8-10 versus 3-5. Shouldn't I notice a substantial difference in power and smoke? It just doesn't seem that aggressive like I thought it would be in those higher stages. I have the ADR1004 downloaded right now.
Any ideas?
Old Apr 21, 2008 | 07:17 PM
Moules's Avatar
Originally Posted by SilverSootXpres
Any ideas?
yeah! download one of the aggressive tunes. adr2000 and up. im hitting 50 psi with the little screw on the turbo all the way out.
Old Apr 21, 2008 | 07:22 PM
Oh man, I just scrolled down and seen the 200's. Can't believe I missed that.
I'll give it a try. Thanks!
Old Apr 21, 2008 | 09:15 PM
J Lent's Avatar
Bet your opinion changes now. I had a similar issue last week, dropped boost 5 psi after changing tunes, turned out to be a busted intercooler.
Old Apr 21, 2008 | 11:54 PM
Big Blue24's Avatar
I'd venture to say you don't have a great wire tap either. If the higher levels don't feel stronger than the lower ones, you have a faulty wire tap, or a bad connection somewhere.
nick2001
Jun 11, 2009 06:41 PM
smog2001
Aug 10, 2007 09:32 AM
dodgediesel
14
Dec 14, 2006 09:54 AM
OldSmokey
Mar 30, 2006 12:17 AM
royta
Jul 13, 2004 06:54 PM
