Adrenaline engine stutter at WOT
Old May 3, 2008 | 03:02 PM
stackit02's Avatar
I ve had my adrenaline on for about 6 weeks now and really like its power. I am having an issue with the engine stuttering at WOT. As soon as it hits red line the engine wants to cut out. I even tried a file they sent me where we have been trying to figure this out that shut the engine off. Dont have much surging anymore with the newer files and power is unbelievable. I also saw an o1 dually pulling at TS Perf. in Bowlingreen and he had the adrenaline on and his engine stuttered at redline. Just wondering if anyone else has experienced this and how to cure.
Old May 3, 2008 | 03:48 PM
GFB's Avatar
GFB
It's most likely valve float. Mine does it when I don't pay attention and don't shift early enough. It sure sounds nasty.
Old May 3, 2008 | 04:38 PM
Big Blue24's Avatar
My truck stutters with Aggressive 2000 tune on PL 5 or higher if i try to hold a constant RPM above 2700 or so. In my case, it is just fueling, no fueling, fueling, no fueling. With the non aggressive tunes, this does not happen. Nor does it happen WOT like you are describing.
My old Juice/ATT Hot would stutter wot in the higher RPMs. I never did figure that one out. I at first thought it was my wastegate fluttering, then I thought it was my clutch slipping. Then I got the Adrenaline and it went away.
Ramble... ramble... sorry not much help.
Old May 3, 2008 | 04:51 PM
Rods's Avatar
Are you talking about my dually ?? maroon with big duals ? I was usen the ADR I had it on the 2000 tune hoping it wouldnt cut out but it did starting around 2800 through mid trac I was just trying to hold it under 3000 but thats kinda hard to do with a sled gaining weight on you near the end it hit 3600 and started to fuel but it broke the clevis .. He has some newer tunes that some of us are testing and the studder is getting better pretty smooth up to 3600+ . Now at WFO on the road it doesnt stumble or anything till 3600 witch is good for drag racers you can do that but for some of us who need a little throttle control in the upper RPMS its still not just there yet little more time and this will b a good box lots of options
btw its not valve float
Old May 3, 2008 | 08:03 PM
GFB's Avatar
GFB
Well, I think mine's valve float because it's more like a loud popping, sounds like it's backfiring out the stacks, along with the studdering and jerking. Usually starts around 3200rpm in 2nd gear.
Old May 3, 2008 | 08:14 PM
Rods's Avatar
Its popping cause theres not enough fuel in those RPMS and being in 2nd at that hi of the RPM range your loosing the load u need so to compensate that u need fuel
Old May 3, 2008 | 08:42 PM
GFB's Avatar
GFB
Interesting. With the little turbo and all the fueling I didn't figure I'd ever run out lol.
Old May 3, 2008 | 08:46 PM
Rods's Avatar
Its the not VP its the box Quads trying to find that sweet spot were its not pouring out smoke like a drag box and others ... For some it works fine for others hes still trying a few things and its getting better everytime
Old May 3, 2008 | 09:16 PM
ahire's Avatar
Could you send me the Test 3 4k tune? Thanks
ahiretn@yahoo.com
Old May 5, 2008 | 09:07 AM
stackit02's Avatar
Yea, that was your dually, a good friend of mine knows you that pulls alot and he knew you were running the ADR. I dont pull mine cause i drive er everyday so i dont mind the stutter alot, but when i wana blow past that mustang that wants to race from time to time i wana get it in the red, hehehe. PS Got a good video cilp of you pulling and comin unhooked, that was crazy!
Old May 5, 2008 | 10:01 AM
Rods's Avatar
Like to see the vid can u youtube it ?
Old May 5, 2008 | 11:58 AM
stackit02's Avatar
Never done the youtube down load thing, but i can try, you will like it, i tried on here and it wouldnt let me, or if you have email i can do it that way for sure. Leaving for Cancun Wed. morn so i will get it to ya somehow before then
Old May 5, 2008 | 12:29 PM
stackit02's Avatar
Got it on youtube here it is http://www.youtube.com/watch?v=bKy41KqwLro it is under title TS Performance truck pull hope ya like it!
Old May 5, 2008 | 12:52 PM
Rods's Avatar
For all the cutting out it done it was still going pretty good LOL
Old May 5, 2008 | 01:19 PM
GFB's Avatar
GFB
Yup, that's exactly what my truck is doing, even at times with the 2000 tune.
