94-99 Dodge Ram Manual Hub Conversion.........Who's running one?
Old Jan 1, 2019 | 08:15 PM
Albino99's Avatar
Originally Posted by u2slow
HD steering is a better setup, and makes a DIY alignment even easier (separates toe and draglink adjustment). Make sure you have enough caster to prevent wandering... more that factory 'spec' is generally a good thing.
My truck is currently setup with the "T-Style" steering. I have been reading many posts about people adjusting the lower control arm cams to achieve more caster (generally a good thing with these trucks).
Old Feb 2, 2019 | 01:13 PM
Albino99's Avatar
Exclamation Last Update
My conversion and steering upgrades are finally done! The truck steers and brakes so much better than stock. For those of you who are curious about final touches, I found that a 4-3/8" hole saw is the perfect size for opening up my hubcap (3rd gen style). The final results look OEM style and gives a clean appearance. I am very happy with the results and would recommend this mod to anyone who wants better braking, serviceable bearings, and a lighter steering feel.
Old Jul 17, 2019 | 02:20 PM
jman00's Avatar
After a few months are you still happy with everything? Anything to report or things you would have done differently?
Old Jul 20, 2019 | 11:03 PM
Albino99's Avatar
I am still very happy with the conversion. No problems at all since the installation. If someone else wanted to do this conversion, I recommend finding a complete F350 dana60 axle like I did.
Old Feb 7, 2023 | 05:35 PM
Wg56's Avatar
I helped two buddies put Ford locking hubs on their 2ndgens. A 94 and a '99.
- 78-79 F250/350 rotors
- 78-97 Ford D60 stub axles
- 78-97 D50/60 hubs and spindles (re-drill spindle to 4-bolt unit bearing pattern)
If you want to go 35 spline and CAD delete:
- 99-04 superduty long side axle (~3/8" short of ideal, but works)
- 78-79 F350 short side axle (trim ~1/4")
Big brakes.... put on complete 95-97 F350 outers. Rotor is 1/2" larger OD, and dual piston calipers. Otherwise, you can look at Speedhouse or Torq for ideas using 14" rotors.
does the f350 dually hubs and knuckles work for the cad delete 35 spline swap
Old Feb 7, 2023 | 08:51 PM
u2slow's Avatar
Never did a knuckle swap myself, but that apparently works too. Big thread on it here
https://www.pirate4x4.com/threads/dodge-ram-2500-4x4-dana-60-hub-removal-and-converison-to-ford-knuckles.874442/
Drw vs srw hubs should not matter.
SilverRam3500
20
Jun 7, 2007 07:27 PM
Mud Ready
Jan 30, 2007 12:57 AM
Yamadad
Apr 15, 2006 10:48 AM
7mmrum
36
Sep 8, 2004 12:09 PM
JARHEAD
Jul 27, 2003 12:17 PM
