94-97 requires hanger modification to tailpipe?
Old Sep 11, 2007 | 08:42 PM
b4black's Avatar
I bought an 4" exhuast from markidaho on ebay. The box says "silverline". Nice looking system, BTW. I have the downpipe on, but when I get to the tailpipe, I notice the instructions say "94-97 requires hanger modification to tailpipe."
Anybody know what this is? It came with a hanger I'm guessing needs to be bolted to the frame. Does it use existing holes? Adding the hanger reallys isn't a modifcation to the tailpipe. There is no mention of the modification in the instructions.
I probably could figure out eventually, but I hope some who has "been there, done that" can offer some advice. Thanks!
Old Sep 11, 2007 | 09:21 PM
gmctd's Avatar
The oem hanger is welded on the 4" curve, mounting bracket attaches to the outside-frame too far back to fit the a\m exh systems with no s-curve - remove and pitch the rear outside-mounted frame bracket, install the new inside-mounted bracket to fit the hanger on the new tp
Old Sep 12, 2007 | 06:37 AM
b4black's Avatar
Thanks
To install the new bracket, do you just eyeball it and drill holes?
Old Sep 12, 2007 | 07:43 AM
gmctd's Avatar
See if it will align with the factory holes first - if not, clamp it and drill
Old Sep 12, 2007 | 08:10 AM
jtlapage's Avatar
If yours waslike mine, it had a hanger with a rubber strap that wont reach your new exhaust tailpipe.. i bought a universer hanger at napa and self tapped it to the frame, and got rid of the old one.
Old Sep 12, 2007 | 10:17 AM
Clayten's Avatar
DTR's Toad Wrangler
I just bent the rear hanger so that it was horizontal to the frame. Then I stuck it into the original hanger.
turbo246
Jan 6, 2010 08:42 PM
ouchman
Oct 12, 2008 12:52 AM
Bookshelf
Jun 16, 2008 01:26 PM
Bookshelf
Jun 9, 2008 09:59 PM
CTDowerTN
Feb 2, 2007 11:01 PM
