5in. exhaust
Old Mar 22, 2005 | 12:57 PM
caleb c.'s Avatar
5in. exhaust
I just called Rip and inquired about his 5in. straight system.He said it has a really loud drone to it.I wanted a really loud truck but don't want the drone to be unbearable.I will be towing a good bit too so that will just make the drone louder.Is anyone running a 5in. straight system that can tell me about drone?If it sounds like too much I will go with 4in straight.I kinda want 5 though.?????????
Old Mar 22, 2005 | 01:13 PM
PowerstrokeThis's Avatar
I have a 5inch system on my 04.5 with a 5inch straight through muffler and it sounds great.
Old Mar 22, 2005 | 01:23 PM
msing's Avatar
On mine drone started at about 1900 and went to 2200 it wasnt that bad putting 36in tall knoby tires on fixed it
Old Mar 22, 2005 | 01:40 PM
PourinDiesel's Avatar
If you want to get rid of the drone on the 5", install a 5" resonator right before the muffler on the 5" kit.
This will nix the drone.
I have a 5" exhaust and this worked perfect to quell the unbearable drone that accompanied the system.
Rip can hook you up with the right parts.
Old Mar 22, 2005 | 04:20 PM
signature600's Avatar
Which muffler would you recommend???
40" or 51" Donaldson (or comparable)
Rip recommended the 51" for me, lots of towing...just hoping it's not too quiet.
Thanks,
Chris
Old Mar 22, 2005 | 04:33 PM
seabee's Avatar
you could pm tcolesanti on here i ran a straight piped 5" for a long time and hauled heavy with it . i have road in the truck while he was pulling my 1970 chevy pickup down from oregon . the drown was not to bad it does get alittle annoying after 12hours on the road but nothing a turn of the radio **** wont fix. the only reason hes not running it any more is it got cut up to run a 6" bullhauler stack threw the bed
Old Mar 22, 2005 | 05:05 PM
caleb c.'s Avatar
I am also thinking of trying the angle iron trick on the pipe if I go this route.I want it really loud,but not terrible in the cab.
Old Mar 22, 2005 | 08:17 PM
88bird's Avatar
Angle iron? please expand more on this "trick"
Old Mar 22, 2005 | 08:22 PM
phox_mulder's Avatar
Strapping a chunk of steel to the exhaust pipe.
Start by strapping it about where the muffler and resonator would have been on the stocker,
go for a drive, then if the drone continues, slide the angle iron back a bit and try again.
Basically changes the structure of the pipe moving the resonating frequency to higher or lower RPM so it doesn't bug you on those long trips.
phox
George&cheryl's Avatar
What is a drone? I have a 5" I loved the sound driving around town but when I hooked up the 5er it was way too loud, you couldn't carry on a conversation without almost shouting, I installed a muffler and it's much better under load.
Old Mar 22, 2005 | 10:50 PM
caleb c.'s Avatar
How long should the angle iron be?
Old Mar 22, 2005 | 11:10 PM
Forrest Nearing's Avatar
I've got angle and strap welded all over my exhaust! LOL! people look at my downpipe and they're like "what's all that crap for!??!"
Forrest
Old Mar 22, 2005 | 11:21 PM
Kyle Graham's Avatar
Aeroturbine makes a 5 inch resonator for Big rigs you could try that it is a drone eater
LilBigd02
Apr 12, 2007 10:54 PM
scarecrow
15
Aug 15, 2005 03:17 PM
caleb c.
Mar 10, 2005 07:13 PM
cummins dsl
Feb 16, 2005 12:34 PM
SMOKEDOG
Sep 13, 2004 12:45 AM
