4th gear low range or 2nd gear hi range?
Old Jun 21, 2010 | 11:36 AM
OrangeBlackHD's Avatar
i cant decide which gear to pull sled in...i pulled last weekend in 3rd gear low range and got 280ft....but the video didnt show much wheel speed at all. I have 285/75/16s and 3.54 gears. Just curious if i could drop down to about a 30 to 31 inch tire and be able to pull in 4th low
Old Jun 21, 2010 | 12:09 PM
graphitecumnz's Avatar
how much horsepower do you have
Old Jun 21, 2010 | 01:03 PM
not sure....got a 4gsk full cut dvs, ddp 140s, 16.5 timing, ?# fuel plate, 215 pump (97).
Old Jun 21, 2010 | 01:04 PM
and wh1c turbo w/hybrid kit...60mm compressor wheel
Old Jun 21, 2010 | 05:37 PM
I'm not really seeing enough power to try 4th on the low side... what RPM did you hold on 3rd low side?
Old Jun 21, 2010 | 07:52 PM
J Lent's Avatar
I just snuffed mine 3 weeks back attempting 4th low on a heavy sled. I'm at 611hp+. I run 2nd high usually.
Old Jun 21, 2010 | 08:21 PM
held right at 3400 down the track. the gov springs need about 2-3 clicks more a piece i think. just did the math and if i run a 31 in. tire and use 2nd in high range ill be runnin right at 28 mph down the track so thats prob the route ill go.
Old Jun 22, 2010 | 07:11 PM
I'm going to say your best bet is going to be 2nd on the high side. I wouldn't go messing with your tires just yet unless you have a mounted set handy or feel like dumping some cash... your 3.55's aren't really ideal for sled pulling if you were to get serious about it anyhow.
FYI, we run 4th low side on a 900+rwhp sled truck...
Billwie
Oct 4, 2008 03:07 PM
Firstgenfanatic
Apr 10, 2008 12:24 PM
Mark Hodowanec
Mar 19, 2007 05:55 PM
trout74
Aug 29, 2005 06:25 PM
