47re not shifting
Will not go into 1st gear without shifting into neutral first, I can get it to start in 2nd if manualy selected and up-shift from there. This is a recent problem after the first occurance, I installed a Trasgo kit. Now I think I have mutiple problems #1 GOV PRES SENCER solonide, #2 higher line pressure. This is an intermittent problem more offten than not but intermittent. Should I install a resister on PIN 31? Or should I replace the GOV PRES Sencer?
I have a same problem when i installed Trans go Kitt. My problem was loose wire in converter clutch solenoid. (Is in valve body 2 pieces). measure with ohm meter both solenoids in valve body! My problems were just at same as you!
Easy to fix just reconnect loosen wire to tin solder.
MR HYDROSEED
Mar 20, 2009 12:08 AM
Brendan
Oct 17, 2007 11:12 AM
00' Quad Cab
Sep 15, 2007 01:44 PM
