42 lbs of boost bad on stock turbo??
ive had guys tell me that pulling over 35lbs of boost on the stock turbo is bad on it. so am i going to need a new one if i keep this up? in 6th i can get it up to round 42 pounds. if i need a new turbo, ill have to get one that will bolt to my exhaust brake. i didnt think that i would be getting a new turbo so i didnt get the remote mount, instead i got the turbo mount. so do they even make these that will bolt to the exhaust brake? always looking for a reason to put a bigger turbo on it
I may be wrong on my numbers but they should be close. I think with the hx35 anything above 34lbs is just creating hot air. The turbo is just out of its effeciency range and is creating hotter air than you want thereby increasing egts. As far as replacing the turbo as long as you do not need a 4 inch elbow (I think hx 40s and above use one) on the exhaust housing you will be good.
If you are not looking to replace the turbo mount exhaust brake, start looking at hybrids. Piers has one, Bob Wagner runs a Dodgezilla. I would imagine HTT and several other vendors have one. Do some digging and you will find what you need. i would bet you would be best off with a 14 cm exhaust housing. Otherwise, you will need to adjust that wastegate to keep the turbo within its efficiency range. Not only are you feeding your engine hot air, you risk grenading the turbo.
Re: 42 lbs of boost bad on stock turbo??
i didtn think that you risked blowing a head gasket till you got up around 50 pounds? so i could switch to the 16cm exhaust housing and keep the turbo ive got or go with a hybrid? like a hx 35/40 or something? thanks alot for the advice. i dont plan on doing any more fueling than ive already got and i didnt really want to ditch the ebrake but i could sell it to dad for his truck and i could go buy me a remote mound. im not wanting to do head work for the fact that it costs money. but i could do it if i just had to.
yes
50 lbs you are running borderline for blowing head gaskets... And i do think that 42 lbs n a stock turbo is useless, due to hot air blowing and raising your egts, the 16 cm should allow cooler EGTS, but i dont know by how much..
Hope this helps...
Tx
Hope this helps...
Tx
my egts arent terrably high, but the lower the better.... what else would the bigger exhaust housing do? lower my egs and raise my horsepower? if so how much? would it raise my boost or lower it?
I'm assuming that if you had an adjustable boost elbow, you could loosen up the set screw enough to pull you down to 35 lbs? That would get you by.
But a bigger turbo is the better option, if you have the $$$
It flows more on top, thus lower EGT even at lower boost.
and a bigger housing will bolt to my exhaust brake? where am i supposed to find one? how much will it cost and will this let me safely run the boost im running now? im not much on fixing things till they are broke. oh by the way, where did u get your experimental powercore bhaf hohn?
