3GSK installed
Old Jan 5, 2015 | 08:56 AM
jj3500's Avatar
3GSK installed
i've got a 96 12V. New to me. +200K miles.
i had this upgrade installed from hearing lots of very positive feedback. Well, its installed.
i am impressed but i guess i set the expectation bar too high.
Truck runs better, pulls and revs freely up past to ~3000K (i haven't revved it up past that).
I also had the fuel plate ground down to zero (?) that is the correct terminology?
My expectation was that the truck would be radically changed. It is bettter, without question. I guess from here, time to open up the wallet.
What would be the next upgrade from here....free upgrade or time to spend some $
any quick free upgrades i've missed?
Mods already done:
16.5 degree timing
MBRP 4" exhaust
boost elbow
AFE open/larger intake.
BD flex plate
BD valvebody
Mag Hytec deep dish tran pan
Old Jan 5, 2015 | 02:25 PM
patdaly's Avatar
Did you slide the plate forward? Adjust the starwheel?
I know the Jessup tuned dually I drove had nothing more than a 4" exhaust, a plate and timing/pump tuning and it was almost scary for a heavy truck.
Old Jan 13, 2015 | 10:01 AM
capt.Ron's Avatar
I think I can... I think...
I have a number 10 plate pushed forward a bit and star wheel adjust and it launches like a rocket. Oh I do have the waste gate blocked off. It's not recommended to block the gate and I certainly don't re3commend it either as there are better inexpensive options but I'm lazy and it's worked great like it is for about 180K miles.
Old Jan 13, 2015 | 05:29 PM
gorms's Avatar
If you don't already have them, gauges are a must for tuning. Pyro, fuel pressure and boost will let you know when everything is right vs over fueling. It is a balancing act.
You can also remove the fuel plate altogether, just be careful if towing.
CTD2001
Nov 26, 2007 12:31 PM
pappyman
35
Jun 26, 2005 12:22 AM
wtmtnterror
Apr 6, 2005 09:18 PM
crossy
Mar 28, 2005 05:12 PM
crossy
Mar 20, 2005 09:03 AM
