370 marines and horrid fuel economy?
id say ur having some issues probably with timing or something else if your mileage is that bad. Has the timing been checked? or verified correctly? any fuel leaks? hows the overflow valve? and what about the fuel filter?
These all impact ur mileage..
Oh and keep ur tire pressure up...
Im sorry its a bit off topic, but with the same plate that you have, 16.5 degrees timing, and same stock (garbage) 370 injectors, i got the same as stockers... They just horribly gag you at idle, and are pretty cruddy in comparison to DDps or II injectors... I dont like 370s, but they are a good bang for the buck...
Rick
i run about 15 hwy at 65 and 12 at 85 around town never had tank without hwy miles kind of wonder why u r so out of wack
I have those? It does stumble at idle or anything?
It lopes every now and then when its cold and im at a stop light or something. I do have the problem of the truck stalling when i suddenly let out of it. Like if Im backin up in reverse and step on it hard and let out, it sometimes dies, but my idle is where it was before the injectors?
rolling18
14
May 9, 2009 06:10 AM
madhat
Aug 18, 2007 10:33 PM
jbjarko
Mar 17, 2007 09:38 PM
