315's and 2" leveling kit
Old Jan 19, 2004 | 06:16 PM
powerwagon440's Avatar
will 315-70-17 fit under my truck with the 2" spacers? ive heard yes and no. think i found a decent deal on some 315's just want to know if it will work or not before i lay the cash down!
Old Jan 19, 2004 | 06:26 PM
phox_mulder's Avatar
Depends on the backspacing of the rims you have.
Factory backspacing and the tires will rub on the control arms at almost full steering lock. (managable)
Aftermarket backspacing of 4.5 inches and they might rub on the rear inside of the fender while turning.
(less managable, and cuts into the tires)
You do realize they are for 17inch rims, and the trucks in your sig came with 16 inch rims.
The 315/70-17's are a little shorter than the 315/75-16's, so they might actually fit.
phox
Old Jan 19, 2004 | 06:32 PM
im going to go with an aftermarket rim like some type of eagle alloy or micky tompson classic II i think it is?
Old Jan 19, 2004 | 07:33 PM
i like the M/T classic II's can u get them in a 17-10? i have seen 17-9.
Old Jan 21, 2004 | 10:50 AM
ramcummins's Avatar
I had a set of M/T classic II's on my '89 chevy. Looked great, nice rims. they have steel inserts in the lug holes, much more durable than most aluminum wheels. Also have a great weight rating BTW they should fit.
Old Jan 21, 2004 | 12:06 PM
gsdog1's Avatar
FWIW - the Dakars in my set-up have 4.5" backspacing, and with my set-up I get slight rubbing on the passnger side nerf bar in a hard right hand turn. It's manageable.
Matt
Old Jan 21, 2004 | 12:19 PM
dodgeman01's Avatar
I got them on 16/8 rims don't know the back spaceing. they are the American raceing Baja rims and 315-75-16 BFG at's
DM01
Old Jan 21, 2004 | 12:34 PM
BigBlue's Avatar
My 305/70/16's rub on my lower control arm with the factory wheels. This is with a 2" leveling kit. They also rubbed before the lift. I'm thinking about going with a set of 315/75/16's instead of a 315/70/16.
PEAKSTRYDE
Oct 11, 2007 04:20 PM
Abbynormal
Jun 8, 2006 08:20 AM
Mark Hodowanec
Nov 12, 2004 06:43 PM
henchman
57
Aug 2, 2004 11:49 AM
mjbarr99
Jan 2, 2004 12:08 PM
