2003 Wheel Question
2003 Wheel Question
What is the offset for the stock 17" X 8" wheels? How do you measure it?
I have the steel 17x7.5's and want to upgrade to an aftermarket wheel. I don't want to rub and want to go with 285's. I found a place that will custom offset aftermarket wheels but I need the exact demensions. Any help would be appreciated.
CTDCAL.
CTDCAL.
Re:2003 Wheel Question
[quote author=CTDCAL link=board=17;threadid=16807;start=0#157569 date=1057635655]<br>What is the offset for the stock 17" X 8" wheels? How do you measure it?<br><br>I have the steel 17x7.5's and want to upgrade to an aftermarket wheel. I don't want to rub and want to go with 285's. I found a place that will custom offset aftermarket wheels but I need the exact demensions. Any help would be appreciated.<br><br>CTDCAL.<br>[/quote]I will tell you if you will tell me who will make the wheel!<br>Ok....I will go first-<br><br>Lay a straight edge across the back of the wheel, measure the distance from there down to where the wheel butts up against the rotor. That measurement is your (back space)<br><br>Make that same measurement from the front and the difference between the two is your off set.<br><br>FYI The factory 03 2500 cast wheels that I have are 17x8, have a 6" back space and the off set is 43.2mm stamped right on the wheel.<br>They fit perfect with 285/70R17's, don't rub or toss garbage up the side of the truck.<br>My problem is I hate the butt ugly hub cap they slapped on it and would buy wheels tomorrow if someone would make the same size wheel.<br><br>Ok...now you go-
Thanks Matt, that was the info that I needed, duh, I guess I could have looked at the stamping on the wheels, did not think about that, I'm feeling pretty thick about now! ;D<br><br>The place I found is at:<br><br>www.stocktonwheel.com<br><br>The Explorer wheel is what I want. Look in the light truck section and scroll down. The website says they can make it in any back space/offset and that 17" 8 lugs are available. I am going to call them this morning and see about price and shipping. Then I will post up and let you know.<br><br>CTDCAL
Here's the ones I'm thinking of. 4.625" of backspacing...will that work? What's the bolt pattern? See any of these that'll work?
this company will also make u custom wheels wheel vintique. there are companies making wheels for these trucks. depends on what u want to spend and material u want..
[quote author=PADZZ link=board=17;threadid=16807;start=0#158115 date=1057775385]<br>Here's the ones I'm thinking of. 4.625" of backspacing...will that work? What's the bolt pattern? See any of these that'll work?<br>[/quote]Those are nice, I looked at Welds but that backspace means one and 1/2" more sticking out the sides.
[/quote]
Welds will work.
Kinda pricey.
Stay away from the 2 piece, you can't keep them clean.
(water gets trapped in the seam in the middle, and collects gunk which chooses to come out after everything is dry and shiny)
They will stick out more, how much depends on the tire choice.
My 16x10 Stonecrusher's with 315/75R16's stick out almost 3 inches.
American Racing has most of the Weld styles, forged with the same weight rating, for cheaper.
I found this out after the fact of course.
Oh, the bolt pattern is 8x6.5,
just don't mistakingly get the ones with 3.625 backspacing, you want the most possible.
I now wish I would have gone with 17inch ones, with the new trucks coming with 17" stock, more tire choices will be available quite soon I bet.
phox
[/quote]
Welds will work.
Kinda pricey.
phox
If you did call Stockton, I am sure that you found out that they are very expensive. I was quoted $155 for a bare(no paint) 17x8 8 lug. That is without shipping. That is just insane for a steel wheel. I have Allied black steel wheels. 17x8 with 5" of back spacing and they cost me $65 each. Obviously they stick out a little more than stock but with my Bushwackers, I think they are perfect. I don't think you will have any problems with 285s rubbing especially if you have a leveling kit. I have 35x12.5 BFG Muds and they just barely rub on my mud flap at full turn.
[quote author=CTDCAL link=board=17;threadid=16807;start=0#158068 date=1057765341]<br>The Explorer wheel is what I want.CTDCAL<br>[/quote]Hey CTDCAL, the Explorer is nice looking, I may call them myself on that wheel.<br>If they would do a 17x8 with 6" backspace plus it should be a "Hub Centric" wheel-- that is where the wheel is centered on the trucks hub rather than the lugs, DC designed the trucks that way so its anyones guess if a "lug centric" wheel would turn true or not on the new trucks. Hub centric wheels means for a special way to attach a center cap. I would like chrome for me!<br>
Matt,<br><br>I was out of town and just got back in so I have not called them for a price and info yet. I will try to get at it today. I like the wheels, but someone above mentioned that they were pretty expensive. Might try the Allied wheels if I can find a source.<br><br>CTDCAL.
[quote author=Matt400 link=board=17;threadid=16807;start=0#161628 date=1058577417]<br>I found these in the correct 17x8 with 6" back space and hub centric design but the manufacture says their 17's will not clear the 2500's brakes??
<br>
<br>[/quote]<br><br>who makes them?
<br>
DF5152 wrote: who makes them?
ed
15
Mar 12, 2003 09:16 AM
