2002 24v best aftermarket lift pump opinions
Old Feb 24, 2011 | 04:42 PM
Davezl900's Avatar
Hi I was wondering which lift pump would be the best to put in my 02 24v. I ultimately want to put an edge juice w/attitude in it. It has 260000 klms on it. I just bought it and I want to get a good lift pump in it asap because of the obvious reasons. Thanks
Old Feb 24, 2011 | 09:49 PM
pquevill's Avatar
A cheap fix is the DDRP FASS direct replacement pump has good solid pressure. Go buy the Geno's garage relocation kit and put at the frame rail. And remove banjo bolts with their replacement fittings. It keeps good solid pressure to the VP44. If you're going with larger mods, then the regular FASS system or Airdog are pretty good pumps.
Q
Old Feb 25, 2011 | 02:20 PM
Davezl900's Avatar
Thanks
Old Feb 26, 2011 | 01:36 AM
MasterLow's Avatar
If you want to buy new pumps every 2-4 years, just buy a fass or airdog. If you want bomber reliability and watch your psi along with rpm's, get a mechanical lift pump like the Fuel Boss or a RASP/ MITUSA.
Old Feb 27, 2011 | 09:53 PM
1BAD4X4's Avatar
Be leary of the DDRP, I have read several instances in where a user had to have it replaced numerous times. Now FASS gave them no issues in replacing it... but still to some having your truck down means money lost.
I went with a Raptor 150, with 1/2" line from the tank to the VP44. Check out www.vulcanperformance.com
Old Feb 28, 2011 | 05:34 AM
dodgeguy71's Avatar
I second what MasterLow said, Glacier fuel boss, mechanical pump, low maintenance, very reliable, no little electric motor up on the frame rail to get splashed with salt, dirt, grime, can keep your original pump installed for a backup or priming after a filter change if needed. Definitely tops in my book.
Old Feb 28, 2011 | 05:54 AM
m.t.hands's Avatar
do yourself a favor and install a fuel pressure gauge regardless of which pump choice you make
Old Feb 28, 2011 | 12:19 PM
Davezl900's Avatar
Thanks again guys! How does the mechanical pump install? And does anyone know where to get one in Toronto area?
jpdodge150
15
Aug 15, 2011 06:09 PM
schu777
Sep 10, 2009 08:50 AM
Old & Injecting
Aug 16, 2008 11:27 PM
98rambaby
Jul 7, 2008 06:49 PM
Bigsmoke3500
16
Jan 1, 2008 09:32 PM
