20% Bio diesel at the pump?
Old Nov 26, 2006 | 05:52 PM
Big Smoky's Avatar
I filled up the other day and half way though refueling I looked on the pump and it said that the fuel contained 20% bio diesel. Has anyone else seen this? My exhaust also smells a little different. Just curious. Thanks
Eric
Old Nov 26, 2006 | 06:07 PM
infidel's Avatar
It was probably luck of the draw that you pulled up to a pump that had B20.
I'll bet if you had looked around that some of the other pumps were straight #2 or other percentages of bio.
Old Nov 26, 2006 | 06:21 PM
Big Smoky's Avatar
I had no idea they were doing that. All the other pumps were just straight #2. It was on the pump that didn't have a roof for the big trucks
Old Nov 26, 2006 | 07:03 PM
merrillr4's Avatar
Eric
You will be fine, I run B20 all of the time.
Old Nov 26, 2006 | 07:11 PM
Shovelhead's Avatar
Administrator / Scooter Bum
I'd run B-20 all the time if the only station in the area would stop paying games with the prices.
One day it's 30 cents per gallon higher than straight diesel,.....a week later it's within a couple of pennys.
And the station is tucked away in a seldom traveled corner of the county, and they don't get many 'hits' on www.gasbuddy.com
Old Nov 26, 2006 | 07:20 PM
Big Smoky's Avatar
Did it make y'alls exhaust smell a little different?
Old Nov 26, 2006 | 07:28 PM
n0ne's Avatar
i havent seen bio diesel at the pumps in my area.. but heck bio diesel has a higher cetane content than straight #2.. so should give ya bit more power technically..
Old Nov 26, 2006 | 07:31 PM
Big Smoky's Avatar
I also added 32oz of Power Service to that tank, not knowing I was filling up with B20!lol My engine is getting some new treatment all together!
Old Nov 26, 2006 | 09:32 PM
LonestarCTD's Avatar
You might want to keep an eye on post filter pressure. If it starts to drop then you might need to change the fuel filter. Usually, the first run of B20 will loosen-up/clean your tank, lines, and everything in between and it all ends up in the fuel filter. Just something to keep an eye on.
Old Nov 27, 2006 | 11:22 AM
AggieJustin's Avatar
It will make your exhaust smell different than running straight #2. I filled up with a full tank of Willie Nelson's B20 the other day on the way home. That weekend while hauling hay, I kept trying to figure out what the strange smell was when I was stopped and idling, then it dawned on me that I was running the B20. Wasn't the french-fry smell that some describe when running B100...more liked french fries cooked in #2.
On the bright side, the fuel system must not be too dirty as I didn't see any drop in fuel pressure during or after the tank.
EricArrow
Jun 16, 2013 09:40 PM
justen920
14
May 14, 2009 12:52 PM
tfarmer96
May 4, 2005 09:59 AM
MK4288
Mar 17, 2004 02:11 PM
c5r
Mar 5, 2003 10:43 AM
